diyAudio Sponsor
Old 2nd April 2011, 02:09 PM   #1
Default 6y6 output tube and Fender Champ(ion)
Hi, all. I wish to seek your advice on the possibility of using a 6Y6 output tube, instead of a 6V6, for my Fender Champ (Silverface from 1975), or the reissue of Fender Champion 600. Is it safe to use 6Y6 in these amps? If it is safe to use it, what are expected changes when 6Y6 is used?
Thank you in advance.
Best regards,
H. U.
Old 2nd April 2011, 02:53 PM   #2
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
please look at these datasheets and you can form your own opinion:
http://frank.pocnet.net/sheets/093/6/6Y6GT.pdf
http://frank.pocnet.net/sheets/093/6/6V6GT.pdf
depending on your B+ perhaps you can, but the screen voltage is also low for the 6y6, so i think you need to do a lot of modifications to make it work...
Old 2nd April 2011, 02:55 PM   #3
kevinkr's Avatar
I'd just say no.. The 6Y6 is good for a lot of things, this just isn't one of them.
www.kta-hifi.net
Old 3rd April 2011, 03:15 PM   #4
Hi. Thank you, Tony and kevinkr, for kind advice. I really appreciate it. It seems that I'd better not use 6y6 for the mentioned amps, unless major mods to accommodate the tube are carried out. As I am not unhappy with 6V6s, I will stick to them. I do not want to take the risk of damaging my precious amps. Again, I thank you both for imparting me with your knowledge.
Best regards,
H. U.
Fender champ circuit low output. Jayoldstuff Tubes / Valves 6 27th March 2011 07:58 PM
Fender Champ 5C1 help needed! Spasticteapot Instruments and Amps 12 27th July 2010 11:45 PM
Fender Footswitch (Champ 25 se) R_Atkinson Vendor's Bazaar 0 9th May 2007 10:04 PM
Fender princeton/champ clone layt Tubes / Valves 6 24th April 2005 06:47 AM
Fender Champ: What Transformers? edsmith Tubes / Valves 2 6th August 2004 12:14 PM
Page generated in 0.08002 seconds (71.29% PHP - 28.71% MySQL) with 10 queries
