valve rectifier series resistors - Page 2 - diyAudio
Old 2nd April 2011, 11:21 PM   #11
trondareo's Avatar
I have found this circuit (PDF) and this circuit using the 5Ц4С
I have also added a warning about the value on the TAO of Tubes post.
Im doing stuff at http://taooftubes.wordpress.com/
Old 2nd April 2011, 11:52 PM   #12
It depends on the type of filter you use, the resistor is to limit peak currents in the rectifier. We always talk about average rectifier current but it's the peak values (@50/60Hz) that are not mentioned in the datasheets, affecting tube life. An L-C filter or a C-L-C filter is much easier on the rectifier tube than a C filter, especially with people using huge filter caps nowadays.
Old 4th April 2011, 06:55 AM   #13
minhaj is offline minhaj  Bangladesh
hi, may be my input will not be useful, though I could not resist myself from speaking.
This is about rectifier perimeter/data, how you design your power supply and what you want the PS to do and load of the following circuit.
4700 ohms is way to high for most of the circumstances no matter what your data sheet/circuit says. I am sorry if I sound harse.
Old 30th May 2011, 10:08 PM   #14
Default another 5u4c datasheet
hi I have found another datasheet
''GSTube.com''. Tubes, sockets etc. Parameters and characteristics 5z4c
it says the same as the previous link 4.7k..... maybe 5u4c just is not suitable for audio and safe?However , I am still using mine with 150r ohms anode circuit resistance provided by the centre tap transformer it seems to be happy.I emailed the lampizator who i basically copy and he said just add 100 ohms if you are worried....
Old 30th May 2011, 10:36 PM   #15
TG is offline TG  Ukraine
Send a message via ICQ to TG
Oh c'mon.
5Ц4С's data just says that being fed with 2x500Vrms and loaded by 5uF capacitor and 4.7kOhm active (resistive) load this tube (average sample, with nominal heater voltage) will generate 122mA current through this load (i.e. will provide 0.122*4700=573.4V on this load).
It has nothing to do with series resistors, current limiting and all that stuff.
Old 31st May 2011, 01:42 AM   #16
Miles Prower's Avatar
This is not true. When I was designing a hollow state power supply, the spec sheet for the 5U4GB (the type I chose for this project because I had a PTX that overvolted badly with Si diodes, and for which the PTX seemed to have been designed) gives a peak repetitive current per plate (Isurge) of 1.0A, and a hot switching peak limit of 4.6A per plate. Given the need to ditch about 100V, from the plate characteristic, an Isurge= 0.8A did nicely. A 34uF (two 68uF / 300Vdc units in series with 100K equalization/bleed resistors) reservoir capacitor gave an Isurge quite close to that value. I used an LC LPF after that where L= 7.0H and C= 220uF. Design nominal DC was 350V; measured DC was 352V. The output o'scoped clean with any residual ripple under the noise floor. The only series resistance comes from the PTX itself.
The only mention of series resistance is in a section for operation with a C-input filter and hot switching. For the project I designed, if it had hot switching capability (which it doesn't) the series resistance comes to about 30R. Nowhere do I see mention of anything like 4K7 in series with the plate. Given the Isurges encountered with this type, the voltage drop would be:
(4700)(0.8)= 3760V
That's absurd.
You should never use a C filter with any hollow state diode, unless it's for very low currents and where ripple isn't a factor, like, ferinstance, a CRT HV power supply. Since it's almost always running at high frequencies and low currents, what do you care if there's ripple? You can't see flicker at a 30KHz rate anyway, and types like the 1B3GT don't need to source much more than one milliamp anyway. So a filter C= 470pF will do just fine here.
Back in "the day", they may have gotten away with it. I actually had a record player amp that used PP 6V6s, and a 5Y3GT with a 100uF capacitor connected across it. They were counting on a tech-illiterate public at large to not notice that replacing the 5Y3s every 4 -- 6 months was not normal. Besides, you could get replacements at just about any pharmacy, grocery store, convenience store, etc., so what did they care?
There are no foxes in atheistholes
www.dolphin-hsl.com
Old 31st May 2011, 10:57 AM   #17
Originally Posted by TG View Post
Oh c'mon.
+1
Old 1st June 2011, 07:53 AM   #18
trondareo's Avatar
Added the link chokesrule found, and a link to this discussion on my post at TAO of Tubes.
Old 2nd June 2011, 03:42 AM   #19
I am talking about people using several hundred uF filter caps on a C-input filter with 5U4's. The power-up flash from cathode-stripping is impressive.
The 5U4-GB datasheet (pdf) is a bit confusing. Maximum ratings:
"Transient peak plate current per plate, maximum duration 0.2 second = 4.6 amperes"
"Steady-state peak plate current of 1.0 ampere maximum per plate." The graph shows 120V drop @ 1A... I call that a supernova
Steady-state, I'm not sure but I think the 5U4-GB is plate dissipation (thermal) limited and I thought thermionic emission limits the dynamic (8.3msec) repetitive peak current, affecting lifetime too.
For a capacitor-input, full-wave center-tapped rectifier, my texts show peak current is 6-10x average rectifier current depending on the power transformer's sec. resistance and filter cap size.
One can easily scope rectifier current by putting a ~10ohm resistor in series with the center-tap of the power transformer secondary (which usually goes to ground).
Old 2nd June 2011, 06:39 AM   #20
richwalters's Avatar
Using a 5U4 with a massive C filter value is an unfair impedance match.....over 100:1. In fact I remember rectifier tubes at that time often being the first failure casualty even with considered soft low uF cap resevoir circuits.
Do what manufacturers did in the late 1960's, go to sand. Only way round it.
Those curious about series resistors in each rectifier anode leg, the value of the resistors should equal the DC resistance of each HT winding side. Or at least that's how it used to be applied.
richy
valve rectifier in PSUD jrenkin Tubes / Valves 21 24th May 2010 11:21 PM
U600 rectifier valve datasheet, please !!! aldovan Tubes / Valves 0 22nd March 2010 03:38 AM
rectifier limiting resistors capacitor input tmhajw Tubes / Valves 20 3rd September 2009 08:30 AM
resistors before the diode in a bridged rectifier: what does it do? jarthel Parts 2 5th September 2006 05:38 PM
resistors in series starrman93306 Car Audio 6 8th November 2004 09:56 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2016 DragonByte Technologies Ltd.
Copyright 1999-2016 diyAudio
