6C33
At 'End Of Life' --3000 hours plus if used well within ratings,--the Cathode-emission goes below that needed to supply sufficient current for the circuit to work properly!
What you mean I think, is what happens when a 6C33 isnt burned-in properly and used 'raw' and goes bang!
Normally a destructive flashover/arc occurs which strips cathode material off the cathode, liberates gas and causes even more arcing to take place!
A Properly burned in 6C33 is quite happy up to 300 volts plus on the plate....
--Not that I run them at this high voltage, but they are more than happy with 150-200V on the plate, which is where I run 'em....
Also, I NEVER 'pre-heat' any tubes. Its FULL +B at switch-on as well as heaters. Never had a problem with Any tubes doing this....
Several hundred Million Tubed TV sets over 50 odd years Cant Be Wrong IMHO!
Bigun, Thank you for this insightful information
Good explanation - thanks.
