diyAudio Sponsor
Old 27th March 2011, 04:01 AM   #1
Default moviola tubes -- other names?
I am having trouble finding these tubes, are there any other names they go by?
These are the tubes in the schematic:
  • 12AX7
  • 6AQS
  • 6X4
Thanks in advance, John
Old 27th March 2011, 04:04 AM   #2
  • 12AX7
  • 6AQS
  • 6X4
12AX7, 6AQ5, 6X4, some VERY common tubes. Google IS your friend.
Old 27th March 2011, 05:08 AM   #3
Send a message via AIM to DigitalJunkie
I"m sure Jim McShane could hook you up.
http://pages.prodigy.net/jimmcshane/
(No affiliation other than a happy repeat customer.)
Old 27th March 2011, 04:22 PM   #4
kevinkr's Avatar
NOS for 6X4 and 6AQ5 are cheap and readily available on eBay. 12AX7A is in current production from a number of sources and some NOS (but not most) is reasonably priced on eBay.
Antique Electronic Supply, thetubestore, and many others will have most or all of these types in stock.
Moviola was probably nothing more than a rebrander (Maker of that amp? I don't think I have even heard of them before), but tubes from Sylvania, RCA, GE, Tungsol, Amperex, Rogers, etc., will work just fine.
www.kta-hifi.net
Old 27th March 2011, 04:56 PM   #5
Kevin,
IIRC, a "moviola" is something a film editor uses.
Eli D.
Old 27th March 2011, 05:57 PM   #6
Maybe it takes audio off the projector or something, Eli. That amp has a ton of gain in the front end. Cascaded 12AX7s? Lord.
Poinz
Old 27th March 2011, 06:14 PM   #7
The O/P from a photocell that "reads" an optical sound track is small enough. Perhaps cascaded 'X7 sections are just what the doctor ordered.
Eli D.
Old 27th March 2011, 10:25 PM   #8
bichela is offline bichela  United States
bichela's Avatar
Poinz
Thats because a magnetic tape head is plugged into the input. I got to build one of these for my cinematograpy studio and film sync block.
Old 28th March 2011, 08:32 AM   #9
This amp presumably comes from a Moviola Film editing table and must date from the 50`s / early 60`s. O/P levels from optical heads were very low then so you would need lots of gain, one unit I know of used an EF86 followed by an ECC81 and was still marginal getting the signal up to line level. The O/P from a mag head is even lower and you would want some EQ even for editing so I would assume this was an optical monitoring amp. The valves should be easy and cheap to obtain, several equivalents available - 12AX7 / ECC83, 6AQ5 / EL90, 6X4 / EZ90 to name but a few.
Barry
Old 28th March 2011, 12:42 PM   #10
I'd be happy to help if needed. Probably you'd want a couple low noise 12AX7s with all the gain.
BTW, pardon the pop up if you go to my site - AT&T at its finest!
can anyone give browser names ??? benjaminshr The Lounge 9 14th November 2009 04:53 AM
famous names ... tomtt The Lounge 2 8th September 2007 03:01 PM
What are some whack band names? infinia Music 14 15th August 2006 05:02 AM
The names Bond... bond Introductions 2 17th March 2005 10:56 PM
names... Mr. Triatic Everything Else 3 3rd March 2002 06:21 AM
Page generated in 0.10659 seconds (79.14% PHP - 20.86% MySQL) with 10 queries
