diyAudio Sponsor
Old 26th March 2011, 03:08 AM   #1
Default Yaqin MC10-T
There is a new model from Yaqin MC10-T and uses four 12AT7 with output still EL34B. How good is the sound of 12AT7 compare to 6N1?
Old 26th March 2011, 07:11 AM   #2
....better. /6,3 v heating of 12AT7 is - short between 4 and 5 pins. Heating wires are between 9 pin and 4 and 5 pins. For 6N1 - 6,3 v between 4 and 5, not for 12 v/
Old 26th March 2011, 10:19 AM   #3
[IMG]Click the image to open in full size.[/IMG]
Thanks for the info... much appreciated, how many hours is needed to break-in a new vacuum tubes..is it true that 12AT7 has a better low frequency response and low noise but at high frequencies is weaker?
Old 26th March 2011, 01:12 PM   #4
Some times.....20-30 years, if the mode is not close to max. power plate...
12AT7 covers all HI-FI band, like 6N1P.
Old 27th March 2011, 08:06 AM   #5
Hi.. can you suggest what best vaccum tube part no. with better sound as direct replacement for 6N1P?
Old 27th March 2011, 08:59 AM   #6
Try Tesla ECC85 or Tesla or JJ, E88CC. Moc dobry.
Old 29th March 2011, 05:11 AM   #7
Anybody there have tried the russian tubes.. are they better sounding specially the 6N1P-EV or EB series with OTK markings...
Old 29th March 2011, 10:55 AM   #8
DF96 is offline DF96  England
No. LF response is set by the circuit, not the valve. 12AT7 works OK up to VHF radio frequencies, so any HF weakness is due to the circuit. 12AT7 can be non-linear, as it was intended for RF mixing, so need to use carefully. If the circuit designer knew what he was doing then it will be fine.
Old 30th March 2011, 03:01 PM   #9
Hi azazello, for 6N1P pin 9 is a shield should I connect this to gnd or just open connection?
Old 30th March 2011, 04:58 PM   #10
....better to ground.
Yaqin MC10-L Need help collating data Hi-Q Tubes / Valves 4 1st April 2011 07:05 PM
need help with yaqin mc10l marley Tubes / Valves 10 30th April 2010 01:40 PM
Yaqin 300b tocaco3 Tubes / Valves 8 19th March 2009 05:57 PM
Yaqin MC10K ramallo Tubes / Valves 0 22nd January 2009 04:42 PM
yaqin mc10k inquisitive Tubes / Valves 33 8th October 2007 12:56 PM
Page generated in 0.08442 seconds (80.23% PHP - 19.77% MySQL) with 10 queries
