| diyAudio Sponsor | ||
Greetings everyone,
Does anyone have any thoughts on using the 6360 or 6939 as a phase inverter? Thanks Ray http://tubedata.milbert.com/sheets/079/6/6939.pdf http://tubedata.milbert.com/sheets/133/6/6360.pdf |
#2 |
Never used either one myself, but it certainly looks like either one would work as an LTP splitter/power amp. Use an active tail load, PP OPT, and insta-final. PP, Class A, and it'll work. Might also serve as a beefier than usual LTP splitter for driving more powerful finals. Just remember to supply the screens from an active regulator, and you're good to go. |
#3 |
I have used a 12L8GT dual power pentode as a phase splitter. Very low transconductance. These look as they would do a similar job - but on overdrive. I would certainly consider them.
Shoog |
#4 |
Would you have a schematic to share?
Thanks, Ray |
| A very odd phase inverter- comments? | GordonW | Tubes / Valves | 6 | 16th August 2008 02:05 PM |
| Phase inverter | ThSpeakerDude88 | Tubes / Valves | 37 | 29th August 2007 03:15 PM |
| 6C8G phase inverter | engels | Tubes / Valves | 4 | 4th February 2007 06:01 PM |
| What is the purpose of phase inverter? | RemoGaggi | Digital Source | 3 | 6th December 2006 05:09 PM |
| Mystery (to me) phase inverter? | porkchop61 | Tubes / Valves | 17 | 6th October 2004 11:16 AM |
| Page generated in 0.08907 seconds (74.15% PHP - 25.85% MySQL) with 10 queries |
