| diyAudio Sponsor | ||
just curious if anyone has compared the sound between simple DC heater psu vs. Volt. Reg. PSU. 1. F.W.B to R to C (10,000uF) 2. F.W.B to LM1084 V.Reg. I'm wondering if the the volt. reg. heater psu limits the sound. This is for line stage. |
#2 |
Hi!
If this is for indirectly heated tubes, the differences will not be worth worrying about. If this is for directly heated tubes, neither will sound good. Either use a current reg, or the dedicated fil regs offered by Rod Coleman, or use the purely passive LCL approach which I prefer Thomas
http://vinylsavor.blogspot.com/ |
#3 |
I disagree, Thomas.
In my recent 4P1L project I used floating 6.3V voltage stabilizer (for indirectly heated), and 3 Ohm resistors in series with each half of 4P1L filaments. No difference in sound VS floating batteries.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#4 |
Hi!
I wrote that there will be no significant differences with indirectly heated tubes so I guess we agree Thomas
#5 |
Hi again,
just saw in your other thread, that the tube you mentioned is actually directly heated. Ok, if you don't hear a difference with that one, it doesn't mean that there will be no difference with other DHTs. I got significant differences between filament supplies with DHTs. Some respond more to the fil PSU, some less. Generally my first axiom in audio is: If you can't hear a difference, it does not mean that there really is no audible difference. Of course the opposite holds true es well: If you hear a difference, it doesn't mean that there really is a one. Best regards Thomas
#6 | |
![]() ![]() ![]() Agree!
#7 |
Thanks Thomas.
yes, for indirect heater. 12au7, 6DJ8,etc... I have never played with DHT's. I do prefer using the LM1084 for fixed voltage, soft start and some short circuit protection for sanity. If you can't hear the difference,............, you save a LOT of money!!!!! |
#8 |
I had trouble with hum in my pre amp so I changed to DC heaters and the hum was still there. The hum was coming from other sources like transformer magnetic field and bad wiring.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software. |
#9 |
I've tried several DC heaters options for DHTs. I'd rank them as follows:
Best: Choke input supply followed by Rod Coleman board Double choke input supply Then: Rod Coleman board Then: LM1084 as current sink LM1084 as voltage reg followed by a CMC (The above are improved by a further LM1084 before, as Ronan Reg) Various other common voltage regs I didn't find batteries were necessary or much better and wouldn't go to the trouble of using them. Andy |
#10 |
Hi!
Different types of filaments also respond differently IME. The 801A / 10Y family the most. Also the further upstream in the signal chain the more critical it get's. In a linestage a 801A can sound anywhere from unbearable to absolutely wonderful depending on the filament supply. But worth the effort IMHO Thomas
| Biasing DC heaters | lazthegaz | Tubes / Valves | 10 | 17th March 2012 05:45 PM |
| 300B DC heaters confusion | cjkpkg | Tubes / Valves | 20 | 23rd January 2011 02:54 PM |
| Changing AC heaters to DC | bereanbill | Tubes / Valves | 5 | 15th May 2009 06:32 PM |
| Tube heaters AC or DC? | soundbadger | Tubes / Valves | 105 | 1st March 2008 10:04 AM |
| PSU for 12V DC heaters | cbutterworth | Tubes / Valves | 15 | 9th March 2007 06:25 AM |
| Page generated in 0.10548 seconds (80.53% PHP - 19.47% MySQL) with 10 queries |
