diyAudio Sponsor
Old 23rd March 2011, 02:01 PM   #1
tobinns is offline tobinns  United States
Default 50c5 schematic question
I'm working on this old phono amp. I'm understanding everything except what is the purpose of the capacitor between pin 6 and 7 (grid to plate) on the 50c5 and is the value critical. + What would larger values change?
Old 23rd March 2011, 04:42 PM   #2
Tom Bavis's Avatar
It's a crude correction for the rise in high frequency that occurs as the impedance of the speaker rises with frequency. Output impedance is high due to lack of negative feedback. (OK, there IS a little in the bass control section) Also provides some protection against overvoltage from transients and clipping (inductive kick if tube is cut off).
HOWEVER, this circuit is non isolated from the power line. You should add an isolation transformer if you intend to use it with anything but the original changer.
Old 23rd March 2011, 05:14 PM   #3
Thanks for the reply. I've aleady isolated the power supply.
Old 24th March 2011, 12:20 AM   #4
The current production Sovtek 12AX7LPS has a spiral wound (hum bucking) heater, which makes it a genuine 7025 replacement. The variant has good sonics too.
Replace the ticking toxic time bomb Selenium rectifier with a 15 cent UF4007. R31 does more than drop a few Volts. It is a peak surge limiter. In the OEM configuration, without an isolation trafo, the B+ supply is connected directly to the AC mains. If the peak surge limiter is absent, the rectifier "fries". I made that mistake over 50 years ago with a Sakes Tarzian M500 Silicon rectifier. FWIW, a CL90 inrush current limiting thermistor along with a tweaked value for R31 that deals with the lower forward drop in Silicon vs. Selenium gets my nod. Increasing the 1st filter cap. to 220 μF. will reduce hum.
Eli D.
Old 24th March 2011, 01:13 AM   #5
tubelab.com's Avatar
It is likely that the electrolytics in this unit will need to be replaced. The originals are rated for 150 volts. That was OK when the line voltage was 110 volts and the selenium rectifier was lossy. Todays line voltage can be as high as 125 volts, so put in 200 volt caps to prevent fireworks.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 24th March 2011, 01:38 AM   #6
Right on! Space will not be a problem. Capacitance per unit volume has gone WAY up over time. Today's 'lytics bury the old time stuff.
Eli D.
50C5 conversion PRNDL Tubes / Valves 17 10th May 2007 07:54 PM
50C5 Triode strapped? ThSpeakerDude88 Tubes / Valves 4 10th March 2007 03:31 AM
quick 50c5 to play around with ThSpeakerDude88 Tubes / Valves 76 26th December 2005 05:29 PM
50C5 add-on amp tubbytwo Tubes / Valves 7 25th November 2004 08:01 AM
Page generated in 0.08404 seconds (72.51% PHP - 27.49% MySQL) with 11 queries
