Tube pre-amp + Class-D amp. any experience?
Old 22nd March 2011, 06:40 PM   #1
rvrazvan is offline rvrazvan  Romania
rvrazvan's Avatar
Default Tube pre-amp + Class-D amp. any experience?
I won't let go of tube amps but in i might build a Class-d amp with a tube preamp for a friend. I'm also considering to build an 3 or four way Ob sometime in the future with tube preamps.
Any experience with this?
Old 22nd March 2011, 06:48 PM   #2
Miniwatt is offline Miniwatt  Netherlands
Miniwatt's Avatar
I've heard very good things about it.
Old 23rd March 2011, 12:14 PM   #3
rvrazvan's Avatar
up
Old 24th March 2011, 01:44 PM   #4
Magz is offline Magz  United States
I run a modified Supratek Chenin tube pre with Gilmore Raptor Class D monoblocks and they sound excellent with my Infinity RSIIb speakers.
Old 24th March 2011, 03:21 PM   #5
rvrazvan's Avatar
Usually people complain about the lack of "life" in class d amps. they have great clarity great dynamics but the sound is not touching. Does the pre-amp heal this?
Old 24th March 2011, 03:48 PM   #6
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 24th March 2011, 07:15 PM   #7
pmillett is offline pmillett  United States
pmillett's Avatar
You might want to look at Ohashi-san's class-D hybrid:
Class-D Description
Pete
Old 24th March 2011, 07:40 PM   #8
revintage is offline revintage
If one have an UCD, the above circuit will not be of any use as the amp already have enough gain. Can only get worse with another stage whether tube or sand.
If you insted remove the OP-amp built in the UCD and instead use an unbalanced to balanced tubestage, a mod will be understandable. Talked to the UCD-people a whike ago and we agreed this could be the solution for those wanting to make a hybrid.
Old 24th March 2011, 08:29 PM   #9
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Last year I started developing such an amp, but gave up temporarily... It has tubes, video current comparator ICs, and MOSFETs. Should sound really nice, theoretically.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 24th March 2011, 08:55 PM   #10
rvrazvan's Avatar
I'm gonna give it a try i think. Hope i can find the tripath chips here
Tube pre-amp + Class-D amp. any experience?Hide this!Advertise here!
Raphaelite Audio Transformers & Sino Tube Amplifier Kits - What's your experience ? kimbal Tubes / Valves 22 14th January 2016 11:39 AM
Help designing Class-A, tube, transformer coupled, studio grade pre-amp gibsonripper Instruments and Amps 9 6th September 2013 01:35 AM
FS: Audio Experience Symphonies Tube Pre-Amp w/ Auricaps mrdon Swap Meet 6 26th November 2008 01:51 AM
Valve Pre Amp & Class D Power Amp Puffin Tubes / Valves 7 16th June 2006 04:41 PM
