| diyAudio Sponsor | ||
I'm going to try an build an output stage in a pre with a ccs load. What was wondering is would I still need to apply grid bias to it?
Thanks Nick Sent from my Garminfone using Tapatalk |
#2 |
The CCS will be on the anode, right? What are you going to do with the cathode? That's what's going to determine what the grid will need.
Pass Labs Pearl Phono -- Pass B1 Preamp -- Pass F5 amplifier -- Pass Labs Pearl 2 |
#3 |
Well I was assuming the dcs would take the place of the grid bias.
I was just going to have the cathode tied to ground. I have never used any ccs so I'm a newbie here. Sent from my Garminfone using Tapatalk |
#4 |
#5 |
If you build a triode amplifier with a CCS instead of a plate load the current through the tube will be fixed at the CCS current. The bias applied to the tube will then set the idle plate voltage. With no bias, the tube attempts to conduct fully. It is limited to the CCS current so the plate voltage goes to a low value (saturation). Too much negative bias results in cutoff and the plate voltage goes to the B+ voltage. The bias can be the usual cathode resistor or LED, or it can be a negative voltage applied to the grid, but it still needs to be there.
CCS loading a pentode generally leads to unstable operation. Ideally both are CCS's and the highest (even by a microamp) valeued CCS will win. In reality neither are perfect CCS's but the tube is generally less perfect and will drift. This makes a temperature dependent flip flop. There are ways to cheat though.
Too much power is almost enough! Turn it up till it explodes - then back up just a little. |
#6 |
Oh man, I feel stupid.
I see the error of my ways. Sorry for the stupidity guys and thanks for helping me see the light, LOL. Nick |
#7 | |
#8 |
hey-Hey!!!,
Let's look at it graphically along the lines of Tubelab's explanation. take your triode plate curves and draw a horizontal line at the CCS's current. Now where along that line do you want the plate voltage? With a grounded grid and cathode the plate voltage will be where the grid=0V crosses your horizontal current line. Make the grid VERY negative and plate voltage will sit at B+( B+ not being infinite, and assuming the tube will stand the dissipation ). You'll need to apply grid bias to deliver plate voltage somewhere between B+ and saturation at grid=0V. cheers, Douglas
the Tnuctipun will return |
#9 | |
Note the schematic of the input stage of the Tubelab SE. The pot (or some means of adjusting the bias) is required on high Gm tubes like the 5842 where none of them actually match the published curves. The SSE used a fixed resistor since the 12AT7 is much more consistent. TubelabSE
#10 |
Another stupid question:
Does it make sense to use a CCS in the cathode of a PP amplifier's output tubes? I mean the cathodes tied together and a CCS is connected between this point and the ground. This could be a kind of cathode bias. |
| parafeed - Gyrator vs CCS anode load | adamus | Tubes / Valves | 51 | 28th August 2011 11:47 AM |
| New PNP HV tranny for anode CCS | richwalters | Tubes / Valves | 12 | 8th November 2010 10:35 AM |
| CCS or V.REG for OP anode | pointy | Tubes / Valves | 0 | 20th January 2010 11:25 AM |
| chocke anode load, please explain me.. | inertial | Tubes / Valves | 7 | 20th February 2009 11:47 AM |
| LL1673 as anode load? | walkwalk | Tubes / Valves | 1 | 13th July 2005 02:04 PM |
| Page generated in 0.11500 seconds (78.78% PHP - 21.22% MySQL) with 11 queries |
