diyAudio Sponsor
Old 16th March 2011, 05:15 PM   #1
Default 12ax7LP substitute
Hello All,
First post here. I did a search and couldn't find anything specific.
Bought a Behringer Untragain Pro 2200 Mic preamp uses. It has a single 12ax7LP Sovtek. I was getting a little crackling and since I have some really nice tubes I thought I'd change it.
So the specs say it's a 12ax7 but when you crack open the case (which isn't easy) it's actually a 12ax7LP. My question is can I swap a different tube in it's place and which would be the best choice. Here's what I have available.
(2) Sylvania Green label 5751 Triple Mica, double support rod.
(1) Sylvania 12ax7a halo
(1) Sylvania 12ax7WA green label (military spec).
(1) GE/Hammond 12au7 halo
(4) 12ax7 from a Lowery Organ (Halo)
(2) RCA 12ax7a halo.
Which one would be the closest match to this Sovtek 12ax7LP?
Thanks for your input,
Mike
Old 16th March 2011, 07:49 PM   #2
Sheldon is offline Sheldon  United States
Originally Posted by TFMStudios View Post
Hello All,
Mike
Any of those, except the 12AU7, will be very close. The 5751 is spec'd for slightly lower gain but, in practice, may be within tube to tube variation of the other AX7 types. Try em, and see what you like.
Sheldon
Old 16th March 2011, 11:22 PM   #3
The 12au7 is a low output tube. I went with the One of the Lowery tubes. I just wanted to make sure there was no big mismatch. From what I could find, the Sovtek 12ax7LP is exactly the same as a regular 12ax7. They just add the "LP" to be fancy. It's a crappy Russian tube no matter how you slice it.
Mike
Old 16th March 2011, 11:42 PM   #4
llwhtt is offline llwhtt  United States
The "LP" stands for "large plate" and there should be little electrical difference between that and any other 12AX7. Try what you have and see what sounds the best to your ears and go with it.
Craig
Old 17th March 2011, 12:14 AM   #5
Mike
While you may have had a bad specimen, the Sovtek 12AX7LPS is anything but bad. AAMOF, the 'LPS is better than much of the remaining NOS. The difference between the 'LP and 'LPS is a spiral wound, hum bucking heater, which makes the 'LPS a genuine 7025 equivalent. The 'LP should not be used in an AC heating situation.
New Sensor "cloned" the Siemens long plate, hence the LP designation. This time, they got it right. If you have a 12AX7 based phono section, you would be very hard pressed to do better than the clean and QUIET Sovtek 12AX7LPS.
Eli D.
Old 17th March 2011, 08:16 PM   #6
Agree.
Old 18th March 2011, 10:32 AM   #7
ruffrecords's Avatar
LP usually stands for Long Plate - on other words its plates are rather taller than a regular 12AX7. The advantage of LP versions is that they tend to have lower inherent distortion. You can buy original Sovtek replacements here:
Rapid Electronics - Electronic Components > Semiconductors
Cheers
Ian
Ian
Old 18th March 2011, 12:58 PM   #8
kevinkr's Avatar
I've a very long history with this tube, and have got to agree completely with Eli on this one. I've got 7+ yr old LPS that still measure well within acceptable parameters after many thousands of hours of use in the error amplifiers of the regulated power supply that feeds my power amp. They also seem to work just fine in phono stages, sound good and are quieter than most alternatives. As Eli indicates the LP should not be used in AC heated applications, but otherwise performs as well as the LPS.
www.kta-hifi.net
Old 18th March 2011, 01:17 PM   #9
316a is offline 316a  England
316a's Avatar
Crackling is usually a sign of an intermittant connection . Try cleaning the pins with some alcohol and a cotton bud , it could be a little surface corrosion
316A
Old 18th March 2011, 01:47 PM   #10
Doz is offline Doz  United Kingdom
Doz's Avatar
I agree about the 12AX7LPS , a really good 12AX7.
My behinger started crackling .. mine had some short plate chinese 12AX7 in it ... it's now got a 12AXLPS in it ... although that didn't sort the crackling, which was some poor soldering on the socket pins.
"To err is human.. to make a real balls-up requires a computer"
No Substitute for... mcd99uk Subwoofers 8 16th January 2011 01:58 PM
substitute for opamp bobcat Solid State 1 27th October 2008 09:14 AM
Substitute to 2N5484 Ryssen Parts 1 18th April 2007 12:58 AM
good substitute? MaXiZ Solid State 4 3rd April 2005 10:21 AM
Page generated in 0.12432 seconds (83.77% PHP - 16.23% MySQL) with 10 queries
Copyright Đ1999-2012 diyAudio
