| diyAudio Sponsor | ||
I have build a CCS 10m45 12B4 pre amp run at 25ma with 120v , I love the sound but randomly a fire cracker kind of sound comes out from the speaker and it is not the power amp. is that the sound of a noisy tube ?
Thanks for any help. |
#2 |
Hi.
I believe that "noise" is referred to in an electronic component, even resistors, it results in a rushing sound, or "white noise". It is basically a result of electrons randomly banging into each other. I don't know what to make of the firecracker sound, but I would think it must come from either the power supply or the constant current source. Cheers. |
#3 |
Could it be due to oxidised pins on the tube or the tube socket terminals that accept the tube pins ? Spray a contact cleaner on them ( and maybe wipe them also ) and check again. Any cold solders...reflow all solder joints again.
AM |
#4 |
Do you have any grid stoppers there?
#5 |
Can be carbon composition resistors warming and expanding.
#6 |
On both channels ?
At the same time ? Faint or as loud as the music you listen to ?
AM |
| 12B4 have a good sound ??? | aldovan | Tubes / Valves | 16 | 22nd June 2010 08:32 PM |
| How Do You Make This Kind of Music? | Darkicon | Music | 6 | 12th November 2006 10:22 AM |
| sound insulation cabinet for noisy computer | mali_aber | Everything Else | 28 | 12th November 2005 06:02 AM |
| 12B4 Battery Bias from (Preamp: Foreplay or 5687 or 12B4 ) | DougL | Tubes / Valves | 3 | 2nd August 2004 06:06 PM |
| How do they make that kind of finish? | VEC7OR | Everything Else | 1 | 25th July 2003 03:56 PM |
| Page generated in 0.07797 seconds (73.13% PHP - 26.87% MySQL) with 10 queries |
