diyAudio Sponsor
Old 14th March 2011, 06:19 PM   #1
Default Output transformer selection
Hello all,
I am working on a 3 stage tube amp project based on 813. For the output transformer I have chosen 10k impedance for primary but I am confused for the secondary. I am planning to use Klipschorns which are stated as 8 ohms, but I recently have found their Impedance to Frequency specifications which seems to be 4 ohms on low frequencies. What do you think shall be the secondary of the output transformer based on the impedance to frequency plots of the horns?
Old 14th March 2011, 07:19 PM   #2
If they say 8 ohms on the back then go with 8ohm secondaries. Its better to go too low then go too high. That graph doesnt make sense unless its just for one woofer and not the whole speaker.
Old 14th March 2011, 07:33 PM   #3
OK, here is another one
Old 14th March 2011, 08:08 PM   #4
frugal-phile(tm)
planet10's Avatar
Sure it does. Only an XO can get the impedance response shown.
And both impedance plots are consistant... be nice to have 3D software displays of impedance (rotatable).
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Impedance and output transformer selection question johan Tubes / Valves 7 7th March 2011 08:16 AM
Advice for transformer selection. beppe61 Power Supplies 20 2nd August 2007 11:37 AM
6G15 output transformer selection layt Tubes / Valves 0 2nd July 2006 12:55 AM
Transformer Selection Audiofng Solid State 9 7th December 2002 08:12 PM
Page generated in 0.07699 seconds (83.19% PHP - 16.81% MySQL) with 10 queries
