diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Tubes / Valves (http://www.diyaudio.com/forums/tubes-valves/)
-   -   5C8S rectifier psud2 modle/rectifier information (http://www.diyaudio.com/forums/tubes-valves/185093-5c8s-rectifier-psud2-modle-rectifier-information.html)
ryuji 14th March 2011 04:41 PM
spent a few hours matching the datasheet curve and data to the psud2 model i made. figured i'd share for anyone who wants to use this beastly rectifier.
some information:
this is a full wave rectifier.
socket: rsh6(the 8 pin large russian socket)
5v filament(big surprise with model # lol) rated at 5A 30 watts
max reverse voltage: 1700 V which means you can rectify up to 600v RMS on transformer side
max nominal current: 420 mA
max envelope temperature: 200 C
about 50v voltage drop at 400 ma, 40v at 300ma
found out that max peak current is 1.4 A but datasheet appears to claim 1.2 A. going by how beastly this tube is, i believe the 1.4
* Vacuum tube rectifiers
*Name Type DRes Vlaw Vfac Vpiv Ipks Ipkr
5C8S, VT, 0.000,1.5, 0.0011, 1700, 99, 1.4
ryuji 14th March 2011 04:54 PM
Forgot to add, Im presently using this rectifier to power 5 807's and 9 pre-amp tubes. it has no troubles at all. The power supply simulation perfectly matches my measured results.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
