diyAudio Sponsor
Old 13th March 2011, 09:48 PM   #1
Default Longevity of output tubes in triode vs pentode
I have amps that operate in both triode and pentode modes(switchable) The output tubes are EL-34s. Is there any difference in longevity between triode and pentode operation? Thanks
Old 13th March 2011, 10:17 PM   #2
DF96 is offline DF96  England
Given the same current and hence dissipation I would guess no difference.
Old 13th March 2011, 10:41 PM   #3
bigwill is offline bigwill  United Kingdom
Depending on the circuit, the screen grids might have a slightly tougher time in pentode mode because they can't swing down with the anode, which will increase the screen current during peaks. However, as long as everything is within spec it is not a difference worth worrying about at all. Pentode is more efficient so you'll be getting more use out of the valve for a given dissipation (and with carefully applied feedback distortion as low or lower than triode mode)
Old 14th March 2011, 03:48 AM   #4
kevinkr's Avatar
Pretty much a non-issue as far as I can tell. A number of my clients had me build ST-70 configured for bi-amplification with one channel in UL mode for the bass and the other in triode mode. Both channels operated at the same quiescent current and the tubes wore out regardless of mode at the same time.
www.kta-hifi.net
Old 14th March 2011, 11:15 AM   #5
Thanks everyone. There were reports on another board that triode operation had an adverse effect on tube life. I am glad to know it is hogwash. Snake oil, snake oil, forever. Thanks again
Triode Pentode combo tubes TheGimp Tubes / Valves 35 6th October 2011 08:13 AM
Pentode to Triode Operation Monjul Tubes / Valves 13 21st September 2010 11:27 PM
Triode connecting a pentode? Original Burnedfingers Tubes / Valves 15 3rd July 2006 05:10 AM
Pentode to Triode trick. Diy martin Tubes / Valves 4 7th November 2005 11:00 AM
triode vs. pentode for pp output. 9am53 Tubes / Valves 1 17th March 2005 07:34 PM
Page generated in 0.08535 seconds (72.52% PHP - 27.48% MySQL) with 10 queries
