Audionote Conquest PCB Layout - diyAudio
Old 1st August 2003, 06:39 PM   #1
hifi is offline hifi  Sweden
Default Audionote Conquest PCB Layout
hello,
I have just drawn this layout for the Audionote Conquest PSE300B amp, and I would be happy to hear some suggestions before I proceed and actualy build the darn thing. ;-)
to clear some things up all the bindingposts and the 6SN7 sockel is on the mirror side, (facing upwards) the rest of the components is facing downwards, also I used two coupling caps because I started with the P4 schematic.
thanks in advance
/ Mikael
Old 1st August 2003, 08:01 PM   #2
Default Schematic
I forgot to attach the schematic.
Old 1st August 2003, 10:04 PM   #3
SY's Avatar
hifi, I've pulled the schematic for the moment since this is copyrighted material. If you've got permission to reproduce it here or if AudioNote has specifically put this into the public domaine, you can put it back up.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Citronic Conquest V12 scheme kvangelo Solid State 20 12th August 2012 07:11 AM
Conquest 1200 amp mickb Solid State 7 22nd June 2009 09:58 PM
AN Conquest Clone modification pawcio Tubes / Valves 4 19th March 2007 08:20 PM
Audio Note Conquest? EsE Tubes / Valves 4 22nd May 2006 11:46 PM
Copyright 1999-2017 diyAudio
