Looking for a Preamp
Old 3rd August 2003, 04:30 PM   #11
Brett is offline Brett
Brett's Avatar
Originally posted by Peter Menting
Lynn OLson certainly agreed when he designed his Amity amps with PP 2A3's.
I've built a couple of versions of the Amity/Aurora now. It's very good,
Will keep you posted as to progress.
Looking forward to it.
Cheers
Old 3rd August 2003, 10:43 PM   #12
mcs is offline mcs  Denmark
Default Re: Looking for a Preamp
Just completed my "Back into tubes" project, a Dyna 70 clone with goodies. Sounds wonderful, so good to hear the detail again. Next project, a line stage/ phono preamp any suggestions?
I would suggest a passive "preamp" like others have done - you could add a cathode follower or plate follower output if you need a lower output impedance. But I don't think that should be nescessary if the preamp and power amp are placed close to eachother.
For the phono preamp I like this circuit: http://www.geocities.com/bobdanielak/phono.html
Best regards,
Mikkel C. Simonsen
Old 3rd August 2003, 11:27 PM   #13
Originally posted by Brett
- make a small enclosure with a selector switch then a volume control and place it beside/under the ST70. Have the selector switch and pots at the rear of the enclosure close to the sockets. Use extension shafts and couplers (try Welborne). This keeps the capacitance after the volume control to a minimum and gets rid of most of the adverse effects of a passive pre.
What do you think about this layout capacitance and adverse effect wise: http://stiftsbogtrykkeriet.dk/~mcs/Test-50.gif
The actual size is 10*16cm. I have just built that board to replace an input selector only box.
Best regards,
Mikkel C. Simonsen
Old 4th August 2003, 07:30 PM   #14
Peter Menting is offline Peter Menting  United States
Default Looking For A Preamp
Mikkel; Thank you for the response, I believe that for now I will go "passive" and see how things work out. As for the preamp Schematic and the Board I'll have to add them to my "reading list", it is wonderful to recieve such response to an inquiry, thanks to all!
Pete
Old 17th August 2003, 12:45 AM   #15
I've just taken a couple of pictures of my new "passive pre" - it looks nice to me ;-)
http://stiftsbogtrykkeriet.dk/~mcs/Remote3/
No tubes visible - they are hiding in the phono stage and power amp :-)
Best regards,
Mikkel C. Simonsen
Looking for a PreampHide this!Advertise here!
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Electret mic preamp - will phono preamp work? darthmullet Analogue Source 6 12th October 2007 07:32 AM
wiring preamp outs on a preamp bonsai171 Solid State 4 22nd March 2004 10:13 PM
