diyAudio Sponsor
Old 10th March 2011, 10:51 PM   #1
Default 45 triode : max 275 or 300 vdc ?
Hello,
Looking at different datasheets for 45 triode, some say 275v max (RCA) some say 300 v max. Is it a matter of older/newer tube ? I have mainly ...RCA tubes
My amp should give an anode voltage (Va-k) of around 280v ...
As I want to have as low an inductance as possible for the PSU rail, I don't want to add any voltage lowering resistors
Thanks in advance !
Old 10th March 2011, 11:29 PM   #2
JLH is offline JLH  United States
JLH's Avatar
You and your 45 would be much better off at 250V or less. If you need more power then choose a bigger tube. If your power supply has too much voltage, then redesign it.
Ah, how beautifully the orchestra sounds before a rain! In a dry sunny day there is no way for the instruments to sound this way!
Old 11th March 2011, 12:02 AM   #3
tubelab.com's Avatar
I suppose that is the proper answer. I however like the sound of a 45 with 320 volts on the plate. All of my tubes are ST shaped 45's that I got on Ebay years ago before they got expensive. None have failed.
I also have a pair of globe shaped National Union NX483's which are 45's with a 5 volt filament. This pair were installed into a Sparton radio in 1929. I don't know how much they were used. I popped them into a Tubelab SE which runs 325 volts of B+ when I built the amp about 6 years ago. They still sound nice and see several hours per week of use.
Too much power is almost enough! Turn it up till it explodes - then back up just a little.
Old 11th March 2011, 08:26 AM   #4
I should have a B+ around 335v and a Vk about 55v > Va-k = 280v
Anyway I have redesigned a previous amp and don't want to buy a new power transformer for the moment (it is a 300-0-300 running now with a 5Y3 to lower B+, was originally for a 2A3 amplifier)
Wanted...design for D3a triode strapped driving 45 jmillerdoc Tubes / Valves 3 10th March 2011 09:10 AM
Is 450V the max of triode strapped 6l6gc pchw Tubes / Valves 7 10th March 2008 03:31 AM
0.300 VDC (from soundcard) on LM3875 GC input !!! Leglandu Chip Amps 28 1st February 2008 03:39 PM
Max B+ for triode-connected KT88 SpreadSpectrum Tubes / Valves 32 5th December 2007 04:08 PM
SE amp using 1619 instead of 45 triode rcavictim Tubes / Valves 9 12th November 2005 06:50 PM
Page generated in 0.07822 seconds (70.55% PHP - 29.45% MySQL) with 10 queries
