| diyAudio Sponsor | ||
Hello gurus and others,
What are the 250 ohms, 500 ohms, 70v and 25v tap for? How crucial is the primary impedance rating, 3.5k to 5k for a 4k transformer? I have a 4k/4 ohm transformer in a schematic I want to change to have 4/8/16 ohm taps. Lastly, will a 40 watt rated transformer work for a 50 watt amp? I have one but I'm not sure if I should use it, any advice would be greatly appreciated. Thanks, Daniel |
#2 | ||
Hi Dan,
These outputs are for driving long distance speaker lines in public address and sound reinforcement systems. You need the higher voltage level to help prevent signal loss and maintain efficiency. A matching transformer is placed at each speaker to mate with the voice coil impedance. Quote:
As an example, I use Acrosound TO-600 transformers from a type UL-II amplifier that are rated at 60 watts. Since I bi-amp my system and cross over at 60 Hz, I can get a clean 100 watts out of them. (That's on a good day If this is for a home stereo system, then no, you don't want to use a lower rated transformer unless you don't need the bottom octave.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
#3 |
Thanks Hollowstate,
Great answers are those that are understood, and I understand now. A couple of clarifications if you don't mind. This is for guitar, an acoustic channel and an electric one. I wouldn't think the low E for each of them would go beyond the frequency limit you stated, yes? And this would be at full output also? Would those lower frequencies be available at lower volumes? Thanks so much for your help... |
#4 |
I believe the low E is around 80 Hz according to tubelab in another post. And yes, you'd get the lower frequencies too. There is no sharp cutoff point. It's just that at very high power the transformer would not provide the clean undistorted bass notes that a larger one may. Remember, we're talking extremes.
#5 |
Thanks for the information, I really appreciate your time... Those distorted bass notes at extremes may be an advantage.
| DIY output transformer info site | smoking-amp | Tubes / Valves | 9 | 12th April 2010 11:35 PM |
| Transformer info? | littlerick | Chip Amps | 1 | 11th January 2010 07:19 PM |
| Difference between SE output transformer and push-pull output transformers | hilbert_mostert | Tubes / Valves | 12 | 8th March 2009 05:10 PM |
| Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms | kelticwizard | Everything Else | 11 | 25th March 2007 05:17 AM |
| info wanted about a output transformer | goudfazant | Tubes / Valves | 9 | 22nd December 2004 05:16 PM |
| Page generated in 0.10393 seconds (73.40% PHP - 26.60% MySQL) with 10 queries |
