| diyAudio Sponsor | ||
Hello,
I plan on using a 5Y3GT rectifier tube into a 10H choke. My driver tube is a 6SN7GTB and the output tube is 6V6GTA. Looking at one of the charts for the 6V6GTA it states an 11 sec warmup with series heaters and no warm up time with parallel connection. Would this be true also with the 6SN7GTB? If not, what are the issues with a fast warm up rectifier with slow warm up driver and output tubes? I have lots of all of these tubes and would prefer to use them if possible. Thanks Gary |
#2 | |
www.kta-hifi.net |
#3 |
Thanks for the quick reply.
I am using motor runs and they are rated for 440Vac. I am using a 350V - 350V transformer. That is what it measures unloaded, I have been a little concerned if they are rated high enough. |
#4 |
The minimum DC voltage your motor run caps. can tolerate continuously is 622 V. and they probably can take a bit more serving as filters instead of current carriers.
If you want to be "fanatic" you can try either the 6087 or 6106. They are 5Y3 variants with cathode sleeves.
Eli D. |
#5 |
Even though there are no issues with these tubes, you could go for an industrial version of the 5Y3 that is a slow warming indirectly heated cathode. The GE type 6087. A bit hard to find and expensive, but a great tube.
"The supercomputer is technologically impossible. It would take all of the water that flows over Niagara Falls to cool the heat generated by the number of vacuum tubes required." ~ Professor of Electrical Engineering, New York University |
| Use CL-90 to slow 5Y3? | Troncones | Tubes / Valves | 7 | 2nd March 2011 02:35 PM |
| Size of 5Y3 tubes? | toufu | Tubes / Valves | 7 | 17th November 2010 12:55 AM |
| TV Horz. Output Tubes used as Output Audio | ppl | Tubes / Valves | 90 | 27th August 2009 02:21 PM |
| Which socket for a 5Y3?? | Richard Ellis | Tubes / Valves | 2 | 11th November 2008 04:41 PM |
| Input Tubes? | d1983 | Tubes / Valves | 7 | 1st June 2007 05:11 AM |
| Page generated in 0.08621 seconds (71.39% PHP - 28.61% MySQL) with 11 queries |
