| diyAudio Sponsor | ||
I heard from someone says the output from tube amp; if they are the same output power (W) as a SS amp, can drive loudspeaker better than SS amp. Is there any proof of this?
I am driving my B&W N802 speaker with a SS amp that has 200W per channel on 8 ohms. I am also curious to build a SE 211 power amp that has only 18W output but is wondering if it can properly drive the N802. Does anyone here tried to drive N802 with 18W output tube amp before? |
#2 |
What is the sensitivity of N802? 211 can produce only 4 watt in Class A1, so it has to be biased in class A2, introducing some ammount of distortion as well, but this is relative.
845 is a better choice.Better specs and 25W in A1. |
#3 |
N802 is 89dB. I saw many 211 SE states it is 15~19W while 845 is over 24W, yet I love the details of 211 although I never heard 845 before.
#4 |
Generally speaking, tube amps have more benign clipping behaviour. Therefor, you do not require the same amount of headroom as a SS amp. 1 Watt of tube power is going to drive your speaker to the same volume as 1 Watt of SS power - you cannot alter the laws of physics.
For 89 dB speakers, 1 Watt 89 dB 2 Watts 92 dB 4 Watts 95 dB 8 Watts 98 dB 16 Watts 101 dB etc... Damping factor is also another thing to consider. Cheers, Chris |
#5 |
Passive Aggressive
Also, what I have heard is that distortion increases with wattage on SS while decreasing with more watts on tubes. So maybe drive your tube amp with SS which seems the reverse of what most folks do who combine the two. Somebody kick me if I'm wrong, its just a 'fact' thats in the back of my head.
You can purchase LDRs anytime to build a standard LDR attenuator or to build my new LDR Attenuator "A Lighter Note". Email me. diyldr@gmail.com |
#6 |
I am using my 45 or 2A3 single ended tube amp to drive my Tannoy 3 way tower speaker. I repaired a Sansui SS power amp for a friend lately. The Sansui amp has power of 100Wrms per channel. Unfortunately, it just lack of the lively sound and dynamics in comparison of my little tube amp.
Of course, I am using large size Lundahl C-core output transformer for my tube amp. That really makes the difference. Large output transformer would have the bass extension that rocks. Johnny |
#7 | |
Also it isn't just the number of watts on offer that you should be interested in. These are normally quoted as watts into a resistive 8 ohm load. From what I've read the B&W nautilus range can have quite demanding impedance minima with difficult phase angles. I think maybe what you may have heard is that because a tube amp is transformer coupled, you can use the most suitable secondary tap for driving the load the loudspeaker presents and thus come up with a decent enough match. This could explain why some lower power valve amps work better with the 802s then some lower powered transistor amps.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Droggon Attack! |
#8 | |
#9 |
Since most speakers are somewhere between 85dB to 101dB, then what we need is just a few watts, right? Why there are amps of 1000W? I have tried to drive my N802 with a Class-A 20W+20W SS power amp but it sucks while the same amp can give good music on a horn speaker.
I heard 211 before; love it but I'm afraid that it cannot drive N802. Can anyone give me their experience between 211 and 845? |
#10 | |
Not the case in any measurements I have done on competently designed solid state and tube amps. Both exhibit rising distortion with power level assuming that cross-over distortion has been properly dealt with. It is often the nature of the distortion that differs. Tube amps generally also produce orders of magnitude greater distortion but usually with a simpler, lower order and more benign spectral distribution. I strongly prefer the dynamics and tonal signature of tube amplifiers to SS, but this may largely be a matter of preference on my part. Solid state amps almost always measure better on the bench, but tube based amps sound better to me driving (most) actual speaker loads.
www.kta-hifi.net Last edited by kevinkr; 8th March 2011 at 03:41 PM. |
| SS Amp with Output Transformer - McIntosh MA 6800 (MA6800) Power Stage Schematic | tiefbassuebertr | Solid State | 3 | 12th January 2010 10:27 AM |
| tube-like SS power amp | rtill | Solid State | 47 | 13th April 2009 12:06 PM |
| SS or tube voltage amplifying stages in an amp with tube output? | ray_moth | Tubes / Valves | 14 | 4th July 2007 03:09 AM |
| tube preamp + SS power amp. | yngwie | Tubes / Valves | 8 | 27th April 2007 01:55 AM |
| 6BL7 as output tube for low power SE amp? | G | Tubes / Valves | 10 | 13th November 2004 08:38 PM |
| Page generated in 0.10530 seconds (88.14% PHP - 11.86% MySQL) with 10 queries |
