| diyAudio Sponsor | ||
Submitted for your (dis)approval, a stereo dual triode preamp with cascaded common cathode stages that are purposfully biased to compress, add second order distortion without audible clipping, and limit transients as a transparent alternative to traditional compressors. It can be adjusted from less than 1% THD to well over 20% without any significant distortion products higher than 2nd order. When the channels are cascaded it becomes a 4 stage common cathode preamp that can operate in two fundamentally different modes depending on the setting of the inverting switch.
The opamps between the tube stages serve useful purposes and without them some of the features such as distortion free inversion, selectable inverting/non-inverting configuration, and input and output buffering would not be possible or at least not nearly as easy to impliment. I'll know in a few days how she sounds. The main purpose is signal conditioning in a digital audio workstation to actually process the tracks through a real analog device that isn't perfectly linear.
#2 |
In order to compress (i.e. reduce the input signal) by non-linearity alone, which I think is your aim, you must have odd-order distortion not even. However, cascading two even-order stages will give odd-order so achieve the desired effect.
#3 | |
I almost have the circuit board drawn out and ready to etch. Hopefully I'll have it working in a day or two. I just need to find one more OPA134 in my junkbox. |
#4 |
Second-order will expand the other side just as much as it compresses the first side, so the original signal amplitude is left unchanged. All you have done is add second-order distortion too. As I said, to compress a signal you need odd-order.
#5 | |
The sonic result of this is yet to be determined. You can speculate all you want to, but until I listen to it working, it's pointless really. It's fun to guess, but in reality I won't know until I plug it in and crank it up. I would concede that the uncompressed negative half cycles will reduce the overall perceived compression, but perhaps with the sonic advantage of preserving at least some of the dynamics of the original signal since only half the waveform is compressed. I don't claim to know, but within a day or two I'll be able to apply as much or as little drive to multiple cascaded triode stages with the bias adjustable for even or odd distortion, or anywhere in between. If it sounds good I'll post some wave or flac files of examples of the effect (and it IS an effect). Last edited by sampleaccurate; 7th March 2011 at 07:59 PM. |
#6 |
I was not speculating, but merely stating mathematical fact. If you are getting compression on one side, and no change on the other, then you have a mixture of roughly equal amounts of odd and even order - not the pure even order you think you have.
#7 | |||
Second order does not expand the other side, and the overall peak to peak amplitude is reduced so overall the signal is slightly compressed. At best half of the waveform remains unchanged, but it certainly isn't expanded. Quote:
You have your facts wrong. The "soft" compression of one side of the waveform yields predominantly second order distortion, not equal amounts of even and odd. If the signal is inverted then passed through another triode stage then yes, the circuit is capable of odd harmonic distortion is amounts greater than the even distortion it can produce when configured to do so. I suggest you look at the harmonic spectrum of the distortion products in the FFT. The 3rd is far below the 2nd. It's common knowledge that a single common cathode triode amplification stage (single ended) generates more even harmonic distortion than odd (in general when not clipping), that cascaded triode stages generate odd distortion products more than even (or mixed depending on the drive levels - both sides of the waveform are being compressed), and that a push pull output stage will generate more odd than even due to cancellation of the even products, so I'm not sure where you get: [/QUOTE] Quote:
#8 |
#9 |
It is a simple fact of trigonometry and power series that even order cannot compress, as even order generates no products at the fundamental frequency. If you have a triode stage which uses some new mathematics unknown to science then I suggest you write it up for publication.
What may be happening is that the compression is being caused by a bias shift, as even order does create DC which will tend to bias the valve back away from its quiescent point and so reduce its gain. This means that your steady-state and transient responses will be different: it will compress sustained signals but not transients, as the bias will not have time to shift. |
#10 | |
If you post your mathmatical proof that partially truncating "one side" of an audio signal doesn't reduce the peak amplitude I'm all ears. And if you can explain how the other side is magically "expanded" I'll really be paying attention. If you want to dispute the results of the FFT take it up with ORCAD. |
| 5654 (6ak5) line stage in triode mode | francoiacc | Tubes / Valves | 27 | 6th January 2011 10:16 PM |
| Ouput voltage of a triode stage on quiescent state should be zero? | Salamander1973 | Tubes / Valves | 5 | 16th November 2010 10:05 AM |
| Question regarding Leak Stereo 20 and 6SN7 line stage preamp | glenz75 | Tubes / Valves | 4 | 28th May 2010 10:46 AM |
| Recommend an input stage triode please | zigzagflux | Tubes / Valves | 20 | 16th April 2008 03:42 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 04:07 AM |
| Page generated in 0.13303 seconds (82.50% PHP - 17.50% MySQL) with 10 queries |
