| diyAudio Sponsor | ||
In my mini-console project I will be using two chassis, one for preamp and one for power amp and PS. On the guitar amp I built (single chassis) I used a two star arrangement with the filter and power tube grounds being returned to a spot on the chassis near the PT and the other signal grounds returned to a spot on the chassis near the input jacks. This worked quite well but with two chassis it seems like it is a little more complicated.
Unlike the guitar amp I am using a can cap for the PS filter. Here is what I have in mind. 1. Connect safety ground of power cord to the chassis at the entrance point. 2. Create isolated star for each stage and run a single ground wire from each (and the input jacks) back to a single chassis connection point on the power amp chassis right next to the can cap. 3. The signal ground from the preamp would not be connected to the preamp chassis at all but brought back to the PA chassis star via. the umbilical cord. 4. A safety ground connection will be brought back from the preamp chassis directly to the safety ground connection on the power amp chassis. Does this sound like a good plan. Another practical question. To solder the can cap ground (case tab) to the chassis will I need to purchase a soldering gun or is it possible to safely do it with a propane torch? I know it sounds ham fisted but my thought is to carefully heat the chassis and make a small pool of solder at the tab location, then push the can cap onto the chassis (and thus the tab into the molten solder) and then remove the torch flame (within a second or so to avoid over heating the cap). Stupid idea? Would it be correct to assume that just securing the can via the twist tabs and soldering a ground wire (that is attached to the chassis) to a tab is inadequate?
mike - www.keepingsundayspecial.org |
#2 | |
Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 6th March 2011 at 08:35 PM. |
#3 |
Again I assume a US tech will add to this!
Safety is the number one issue. ie no differences in potential between chassis. Then ensuring no current ground loops. The resistance between grounds must not interfear with automatic disconnection of supply under fault conditions. Any cord connections that are removable should be fitted with a plug socket with live supply breaks first before ground. Regards M. Gregg
What is the sound of one hand clapping? Last edited by M Gregg; 6th March 2011 at 08:45 PM. |
#4 |
Cap cans are usually aluminium, and so not solderable without special flux. Also, heat is the enemy so not a good idea. Use a clip.
#5 |
Thanks guys.
M. Gregg, Am I understanding correctly that you are saying to connect the grounding star in the preamp chassis to that chassis and then connect that chassis' ground to the main ground connection on the main (power amp) chassis? Also is a mechanical connection of the can cap to the chassis and a separate electrical connection OK or do I need to make the mechanical (clamp) connection the only electrical connection?
#6 | |
Regards M. Gregg
What is the sound of one hand clapping? |
#7 |
Thanks, the safety issue is clear to me now.
The style can that I have has the four "ears" that go through the chassis and are then twisted to secure it. Normally I have seen these with one of the ears soldered to the chassis to make the electrical connection. There are two places on the chassis where one of these cans can be installed. One is cut right in the metal of the chassis and the other is an insulator (some kind of fiber) which is attached to the chassis. I could easily mount to the insulator and then run a wire to the desired ground point but the insulator is closer to the output tubes than the other mounting point and I would prefer as much space as possible to keep the cap cool. That is why I was wanting to use the direct to chassis connection. You can see the two mounting choices here...
#8 |
Could you show us a picture of the cap you intend to use.
I agree with keeping it away from heat! Regards M. Gregg
#9 |
I would suggest that some of M.Gregg's advice could be modified a bit.
Given that the preamp chassis has hazardous voltage on it (but not primary side mains) and the main amp uses a commercial power transformer, then a plug-socket connection between main and preamp chassis would be acceptable, as long as all the connection terminals were shrouded and a hazard sign added, and the caps in the preamp chassis discharge within 60 seconds of the connection being pulled. There would be no requirement per-se to have a PE (protective earth) connection to the preamp chassis, but there would be a practical need to electrically connect the preamp chassis to the main amp chassis to extend the nominal earth screen shielding. The circuitry in the preamp is best made floating, with the preamp star 0V being connected (via umbilical cable) back in the main amp at the local star ground point of the next signal stage (which may not be chassis ground if that is placed closer to the power supply or speaker socket). If shielding is used in the umbilical cable then it should be connected to the 0V star points at either end. The PE from the mains cord should be a separate chassis connection from any other ground/chassis connection. It should not be the amp star ground point to chassis. Only make one 0V ground connection to chassis. Many prefer to do this at the input socket(s), but I find that practical influences can dictate other positions, such as at speaker output jacks, or at an output stage / main filter cap point (as per your filter cap mounting issue). Use a distributed star ground scheme daisy chaining out from that point. (ie. your original guitar amp with two chassis connection points is not as effective as a single point scheme). Ciao, Tim |
#10 |
Just a point of interest.
In the UK if a system is extended into another enclosure wheather that extention is mains or an extention of the electrical system voltages (which may under fault conditions become dangerous) that enclosure must be at earth potential. You cannot rely on a connection using part of the other chassis to provide continuity of protective earth. However this may not be the case in other countries. Regards M. Gregg
| Chassis Grounding and rectifiers | Captn Dave | Tubes / Valves | 7 | 10th January 2009 05:46 PM |
| Chassis Grounding Problem !! | excetara2 | Car Audio | 6 | 28th September 2008 01:04 AM |
| chassis grounding question | mnr102 | Solid State | 2 | 12th July 2008 09:14 AM |
| Grounding chassis | borges | Analog Line Level | 1 | 16th March 2007 08:58 AM |
| Grounding chassis | Per | Multi-Way | 1 | 17th December 2002 10:21 PM |
| Page generated in 0.13152 seconds (89.10% PHP - 10.90% MySQL) with 10 queries |
