| diyAudio Sponsor | ||
Does anyone have info on this Amp or Company? Might be a no starter or out of business, but this appears to be an easilly modified platform good for either near triode or triode connection. R4 by the way is actually 470k per parts list I have. Thanks
#2 |
It looks as a pretty good amp without any modifications. You can get nothing better changing it from ultra-linear to triode mode, just less power, that's it.
The devil is not so terrible as his mathematical model! Wavebourn: We Create Creativity! |
#3 |
I thought it looked OK myself, pro input appreciated, unfortunately all thats left in supply box are two ASL PT30's someone had them rewind without the ultra taps, so I guess I will try it as triode connected and aim for 17-18 watts.
#4 |
If the power trafo has some extra filament current, ditch the 12AU7 and install a 6FQ7/6CG7. The 'U7 has linearity issues.
Another easy upgrade is to replace the 1Nnnnn diodes with the corresponding UFnnnn parts. UFnnnn diodes are MUCH quieter than the corresponding 1Nnnnn parts.
Eli D. |
#5 |
Thanks for the advice, the transfomer I have is 360 V 200 mA - good for 450 or so DC but sadly specd for 3 amps 6.3 and another winding for 1 amp 6.3 - obviously good only for AC heater supply. Found some 6.6-6.6 CT toroids at All electronics, 8 amp rating, got em, they are powertronix, well made
| AMW Acoustic Labs A440 - looking for info | Brisso57 | Multi-Way | 7 | 1st December 2010 12:46 AM |
| Audio Alchemy options | iep | Digital Source | 5 | 28th September 2010 12:01 AM |
| Audio Alchemy Dac's 1.0, 1.1, 2.0 etc | Puffin | Digital Line Level | 3 | 22nd December 2009 06:06 AM |
| Audio Alchemy | jcsveth | Digital Source | 1 | 27th December 2006 07:49 PM |
| audio alchemy help | HIPCHECK | Digital Source | 2 | 1st June 2005 07:11 PM |
| Page generated in 0.07613 seconds (77.80% PHP - 22.20% MySQL) with 11 queries |
