diyAudio Sponsor
Old 3rd March 2011, 09:13 PM   #1
Default OP & tube power transormers
Hello
I would like to know if someone used or know about these transformers?
One of my friend who designed transformers warned me these transformers with the shared parameter impossible to be real!
1 output transformer SE 3.5K / 5K EL84 6BM8 ELL80 6BQ5 on eBay.ca (item 300502785423 end time 09-Mar-11 12:14:51 EST)
1 power transformer tube Amp Preamp 6BM8 EL95 ECL86 on eBay.ca (item 300498610035 end time 29-Mar-11 02:25:47 EDT)
I have not much experience with transformers
Any advise, comment welcome
Thank you
Greetings gabor
Old 3rd March 2011, 09:32 PM   #2
BudP is offline BudP  United States
BudP's Avatar
These appear to be good quality. They are definately in the minimalist cost, commercial production size, range. This is not bad at all, but you must make sure that your expected current loads, in AC terms, suit the specs.
Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa
Old 3rd March 2011, 09:44 PM   #3
Thank you!
If the data of the transformer OK I can use them for these amp..
At least I think.
May be I need a bigger power transformer..
http://www.geocities.jp/mutsu562000/...m/e/hp790e.htm
http://www.geocities.jp/mutsu562000/e/hp908e.htm
Greetings gabor
Old 3rd March 2011, 10:56 PM   #4
Knarf is offline Knarf  Denmark
Knarf's Avatar
Gabor,
Am I missing something, or is there a drawing error in your schematic? Looks like the anode of V11A should go to the emitter of Q2 and not the anode of V5.
- Frank.
Team Thermionic
Old 3rd March 2011, 11:50 PM   #5
Hello
Please go to the Japanese website you can study the schematic there.
I didn't draw the schematic.
In case if there is a mistake it would be good to know!
Greetings gabor
Old 4th March 2011, 12:34 PM   #6
Knarf's Avatar
Well, that should teach me not to reply to technical questions late at night...
I have checked the original article, Gabor, and the schematic connections does indeed seem to be intentional. Unfortunately I cannot help you with your original question, though I would very much like to hear about your experiences with this design, once you have built it.
- Frank.
Team Thermionic
Poor power output, op amp based headphone amp. dannybeckett Solid State 13 27th September 2010 08:31 PM
Tube+OP My headphono & preamp soro Tubes / Valves 0 17th July 2010 09:57 AM
WTB :Pmi op 271AZ, Tube Mulard CV2493 (Match-pair), Toshiba 2SA1941 & 2SC5198 BAM-235 Swap Meet 3 28th January 2008 07:53 AM
tube/op amp/class A buffers jeffshort2000 Chip Amps 1 8th September 2007 01:17 AM
Best Power op amp pundip Solid State 12 8th March 2003 06:59 AM
Page generated in 0.09996 seconds (74.92% PHP - 25.08% MySQL) with 11 queries
