diyAudio Sponsor
Old 3rd March 2011, 04:10 AM   #1
Tony is offline Tony  Philippines
Tony's Avatar
Send a message via Yahoo to Tony Send a message via Skype™ to Tony
Default Tony's 6H32 pre-amp
Hi All,
I was encouraged by this tube when I swapped those with the stock tubes in my Sakua-AV200 hybrid amp, so now i decided to build a preamp out of it. configuration is cascaded common cathode-common anode using one bottle per channel....
I borrowed an Alexan HC961 plastic casing from my son to house this preamp, i then proceeded to cut out holes for the tube sockets and other parts and started mounting them....
after assembling the power supply, I checked the raw dc voltage, the power traffo i built was intended for another project, but a lightbulb flashed in my head yesterday and off i go to build ths amp...
I decided on a plate load of 4.7k, I felt that it was just about right for the B+ available:
looking at the curves, at a plate of about 40 volts, grid bias needed is about 0.56 volts, now a silicon diode like a 1N4007 surely fits the bill.... so then consruction can be completed.
more pics,
completed amp:
this is the schematic of the completed amp:
I would like to mention that the power supply uses a common mode choke to filter both sides of the plus and minus sides of the psu isolating the front end of the psu stage with the rest of the amp.
set-up and listening test:
I put aside my 7N7 pre-amp and hooked up this pre-amp:
so how was the sound?
like always, i liked the "hotel california" on this pre-amp, i can hear the bass guitar and kick drums, not so loud but distinct.......like the other amps i built, this amp is very quiet, no hum, no hiss no extra noise inspite of its being housed in a platic case.....
Old 3rd March 2011, 08:33 AM   #2
analog_sa's Avatar
May be good to correct the tube type as many will get confused.
Old 3rd March 2011, 08:37 AM   #3
Tony's Avatar
ok, 6N32, which is also 6922, 6dj8....
Old 3rd March 2011, 04:52 PM   #4
analog_sa's Avatar
Or maybe rather 6H23?
Old 3rd March 2011, 05:38 PM   #5
kevinkr's Avatar
I'd say so based on the shown data sheet..
www.kta-hifi.net
Old 3rd March 2011, 05:43 PM   #6
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
6Н23П (Русский) = 6N23P (Latin)
The devil is not so terrible as his mathematical model!
Wavebourn: We Create Creativity!
Old 3rd March 2011, 05:47 PM   #7
I really don't mean to be rude, but why would you run a nice, linear triode like 6N23P with that kind of a loadline?
Old 3rd March 2011, 05:50 PM   #8
Wavebourn's Avatar
Because everyone has his/her right on trials and errors when learning.
Old 3rd March 2011, 06:26 PM   #9
Cassiel is offline Cassiel  Greenland
Cassiel's Avatar
Yeah, but learning it's not for everyone. Be proud of your failures then and keep in mind that success sometimes leaves you cold.
BTW, Wavebourn you'll be a good father.
Old 3rd March 2011, 07:13 PM   #10
Wavebourn's Avatar
Thank you Stalker; I have 2 grand-daughters.
By the way, the first my amplifier schematic I drew when I was a kid did not contain anode load resistors: I did not understand then why they are needed. The first my transistor radio receiver did not have bias: I did not know why it was needed. Also, it did not have AGC.
tony's 6LU8 push-pull power amp build Tony Tubes / Valves 6 15th February 2011 09:07 AM
MC pre pre amp for shelter 501 MK11 cjcc67 Analogue Source 19 24th May 2010 07:17 PM
Tony's 300B (standard model) markaudio Twin Audio 27 17th March 2010 06:45 AM
Blown amp pre-amp in or HU pre-amp out? scraph Car Audio 5 23rd January 2009 12:58 AM
Page generated in 0.11805 seconds (80.35% PHP - 19.65% MySQL) with 10 queries
