Not quite DIY
Not quite DIY
Old 1st March 2011, 03:35 PM   #1
Markhh2 is offline Markhh2  United States
Default Not quite DIY
but I've learned a lot lurking here. Sadly time, space and complete lack of skill or knowledge limits my DIY abilities. Instead I worked with James Burgess to have these amps built. WE91A circuit with 6sj7 driver tubes, hashimoto OPT's, Angela PT, ASC oil caps, teflon V-caps coupling capacitors, etc.
I think they look really nice. The feet are myrtlewood and the top was fabricated by front plate express. The power cords are soundstring's that I've used on other amps and really like - and the captive cords will keep me from fiddling with expensive PC's.
I'm hoping these are my last amps for a while. Can't imagine after all the thought and effort that went into them I'll want to see them go. James is running them in for a day or so and I should have them next week. They'll feed a pair of Audio Note AN/E spe's fed by an Art Audio/Gill Elise LT DAC with volume.
Old 1st March 2011, 05:28 PM   #2
kevinkr's Avatar
Not quite DIY
Nice!
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 1st March 2011, 05:32 PM   #3
TheGimp is offline TheGimp  United States
TheGimp's Avatar
Nice looking setup. I like the mirror imaging.
Old 1st March 2011, 06:43 PM   #4
Yeah I really wanted that layout The RCA's are on the sides and the binding posts in back, both on the correct side
Old 1st March 2011, 07:13 PM   #5
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Not quite DIY
Very pretty & nicely executed. What's with the plastic bags over the OPTs?
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 1st March 2011, 08:47 PM   #6
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Not quite DIY
polished supply caps
each tube monted on each their own 'personal' printboard, also holding solder lugs
neat 'tricks'
how much did you pay for this custom work ?
Old 1st March 2011, 08:57 PM   #7
Matt BH is offline Matt BH  United Kingdom
Very nice
Is that a CRT clock next to them?
Cheers Matt.
Old 1st March 2011, 10:46 PM   #8
woodturner-fran is offline woodturner-fran  Ireland
Very nice work!
Old 1st March 2011, 10:57 PM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
Sure looks like it. What's it used for?
~Tom
Old 1st March 2011, 11:37 PM   #10
Cant wait for the reply on that bad boy
looks like one of the Ask Jan First ones.
I have a crappy old Kenwood scope that will be getting the vector graphics treatment
Cheers Matt.
Not quite DIYHide this!Advertise here!
DIY tube/phono pre in the same case as my DIY dac? ben62670 Analogue Source 3 29th October 2010 08:46 AM
diy disco lights? (based on diy rear projection tv idea) dion_lilley Parts 0 4th July 2007 01:34 PM
Noise Reduction DIY >not gated< DIY? orson198305 Instruments and Amps 3 25th June 2006 06:24 AM
Wondering if Upcoming DIY design will work with Tubes? Cheap DIY Kits? demon2091tb Tubes / Valves 28 7th December 2005 05:51 PM
