| diyAudio Sponsor | ||
I am looking to buy an oscilloscope. I don't have any experience with them.
What do you guys think of the Tektronix TDS714L digital scope or other Tek digital scope for stereo equipment application? How do the analog scopes like Tek 2246 or 2465 compare to the Tek TDS714L for stereo equipment application? |
#2 |
All I can say is that for tube audio, you don't really _need_ to shell out $3k on a scope. I'd settle for a simple dual beam analog 'scope.
#3 |
As above.
Look for a minimum of 20 to 30mhz bandwidth, dual channel, and choose a model that has a high accelerating voltage for the CRT (10 kv or above to give a bright sharp trace).
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#4 |
Are there anything that the Tek digital scope like TDS714L can't do but the analog scope can?
I agree the TEK TDS714L is over kill for audio but I think it would be useful for other things as well. |
#5 | |
I also have a good studio quality audio interface in my iMac and software that can do some analysis on the sound, like FFT and harmonic distortion. |
#6 |
I've worked in electronics for 40+ years and have used most of the Tek scope models at one time or another. For audio signals I would look for one of the older digital models that work dual mode. That is they work as an analog scope most of the time but have digital storage mode. With a straight digital scope it is very easy to miss some of the fast rise time events that can occur faster that the sampling time of the sweep rate you are using. Thats not to say I don't use digital scopes, I do. It's just that you need to look at the signal at several different sweep rates to make sure your not missing things. Some of the other features like FFT and wave form capture can be very usefull. If you want these other features then go for it. If you want a simple trouble shooting tool then go for the analog scope. BZ
#7 |
The shots here were taken with my analogue scope,
The best sounding audio integrated opamps My thoughts are as per BZed's above. Scope I use is shown in post #1026 It's a bit like comparing a digital camera and film. The digital one won't show the finest detail when you zoom in, the analogue lets you winkle out what's there limited only by the trace thickness and noise.
#8 |
Thank you guys for the input
#9 |
I absolutely love my TEK 2465B. 4 channels, 500 MHz. I picked it out of a scrap heap for free and replaced $25 worth of caps in it. Best $25 I've ever spent. The 2465 is an analog scope with some digital functions (cursors and readout). Some of them have a digital storage option.
~Tom |
#10 |
I am actually thinking of getting a 2465/A/B.
Do you think it is worth it to get a 2465B or the other versions would be just as good? |
| Tektronix 465B Oscilloscope | dan45hk | Swap Meet | 2 | 2nd January 2010 10:12 PM |
| Tektronix 335 Oscilloscope | dan45hk | Swap Meet | 2 | 2nd January 2010 10:11 PM |
| Looking for Tektronix 465B oscilloscope | h_a | Swap Meet | 4 | 30th December 2009 08:37 AM |
| Probes for Tektronix oscilloscope T935A ? | 00940 | Equipment & Tools | 1 | 14th May 2009 06:09 PM |
| Oscilloscope - Tek 2465A, HP 54112D Any experience | harvardian | Parts | 11 | 26th September 2002 09:18 AM |
| Page generated in 0.10312 seconds (77.87% PHP - 22.13% MySQL) with 10 queries |
