| diyAudio Sponsor | ||
I always saw few SETs with Toroidal Output Transformers, most use laminated trafos. Why this happen?? Toroidal are more expensive?? Or Laminated offer better sound quality?? Need your opinion to know what is the better choice, Toroidal or Laminated for a 6C33 SET, 15Watts/8 ohms, I will use 8 ohms tap only. I accept suggestions of both cores you may know. Any help will be appreciated. Gustavo
>Never go to a psychiatrist, adopt a cat or dog from the streets. On the streets pets live only two years average. |
#2 |
Gustavo,
Searching this forum you will find much info on toroidal, EI and c-core output transformers. In my opinion and experience the c-core transformer is the best option, but once more, look around here. |
#3 |
For SET - anything but not not toroidal. Fixed air gap toroids are too problematic to make. Distributed air gap cores are made for chokes, not audio transformers.
#4 |
LinuksGuru,
Despite my preference for c-cores I am not so sure that "all toroidals are the same and therefore not good for SE". I know that toroidal cores are not only available as uncut closed loops but also in cut halves (like c-cores). Applying appropriate airgaps should not be too much of a problem with cut toroids. |
#5 | |
Technically even at home its possible to use band saw to cut them in halves, and then glue with epoxy and tiny piece of mylar film in between to make air gap, but this is kinda awkward. Water or laser cutting machines capable to work with so thick piece of metal possibly available somewhere but I'm not sure. EI/double C cores are more suitable to make precision air gap, no reasons to mess with toroids for SET. |
#6 | |
why not cut a bundle of 'half moons' of transformer iron sheet make two half moon plastic bobbins for the winding when forming a perfect circle, they should all slide very easily into each other, and voila, a toroidal double C-core |
#7 | |
What is to gain with this? Good quality c-cores are annealed after forming; bending iron to form a core without annealing will impair the quality. At the end I see no advantage in winding a circular core (with all possible haphazardness) over winding a neat straight coil for a c-core. Quite a lot on this subject has been discussed in other threads. |
#8 | |
stacked iron with plastic bobbin like the ususal just different, toroid style I dont know if theres any advantage, no clew, nada nor do I know what kind of winding machine needed but with bobbin, open winding should be possible, and different from regular toroid but one major problem I guess no parts available anywhere but hey, this is DIY, right ? |
#9 |
Thanks for your comments. I thought the best sound was clearly known. If the best sound is uncertain I would like to read your technical considerations on the subject. Thanks a lot, Gustavo
#10 | |
never forget to read the first post, eh well I forgot I would say C-core, surely but C-core aint just C-core, they may be different too but there could be more to it than just choosing core type like production quality, winding design, impregnating, etc whatever, I have heard pretty crappy sound from amp using top quality trafo and I dont doubt its possible to get real good sound from budget quality components, trafos included |
| Output Tube biasing for Toroidal Output Transformer | gingertube | Tubes / Valves | 7 | 17th April 2005 04:40 PM |
| toroidal SE output transformer | noyan | Parts | 10 | 11th July 2004 10:41 PM |
| toroidal transformer | djdamix | Parts | 3 | 15th June 2004 08:11 PM |
| Toroidal Transformer | sma | Solid State | 3 | 3rd February 2004 07:55 PM |
| Page generated in 0.11333 seconds (77.98% PHP - 22.02% MySQL) with 11 queries |
