diyAudio Sponsor
Old 27th February 2011, 05:44 PM   #1
Troncones's Avatar
Default Can I use a 12AX7 with CT 6.3V?
How do you wire it?
The Myth: A hand full of Tubes, Caps, Resistors and Iron and you have an Amp. The Reality: You have self induced Dementia. Newbie.
Old 27th February 2011, 05:47 PM   #2
boywonder's Avatar
Yes, one end to pins 4&5 (tied together) and the other end to pin 9.
TDSL Tube data [12AX7]
Old 27th February 2011, 06:05 PM   #3
Troncones's Avatar
Thanks Scott,
Would it be the same for a 6N2P?
Old 27th February 2011, 06:42 PM   #4
Originally Posted by Troncones View Post
Thanks Scott,
No. The 6N2P is wired to have 6.3v on pins 4/5.
Irritating because it would be nice to be able to swap the two types for listening comparison.
Gary
Old 28th February 2011, 12:36 PM   #5
if one of your heater winding is grounded .
you could end up whit
12ax7
pin 4 +6.3v you shouldnt tie these together .
pin 5 +6.3v
pin 9 ground
use a switch witch is a 2 position 1 pole . ( dual if your using two 6n2p )
to switch pin4 on the 6n2p
6n2p
pin 4 ground
pin 5 + 6.3v
pin 9 ground . this does NOT matter as its only a shield and its not connected to any further elements in the tube .
in this way you could use both
Old 28th February 2011, 06:01 PM   #6
Troncones's Avatar
Thanks v4lve,
I will try this when I get my other Tx. The one I'm using for the test build only has 3.15-0-3.15.
Old 28th February 2011, 06:11 PM   #7
it does not matter if its center-tapped . if im correct . if someone thinks im wrong please correct this .
Old 28th February 2011, 06:49 PM   #8
DF96 is offline DF96  England
12AX7 requires 6.3V (or 12.6V). 3.15-0-3.15 is 6.3V CT. You need 6.3V, you have 6.3V - so no problem.
Old 1st March 2011, 03:05 AM   #9
Troncones's Avatar
With the 6N2P how can you put 6.3 on pin 5 using CT 6.3V?
Old 1st March 2011, 10:10 AM   #10
I don't understand the question. Heaters are almost always about the voltage beween two pins, not the voltage on one pin. (minor exceptions are those valves which tie one side of the heater to the cathode, like some beam deflection mixers). You need 6.3V, you have 6.3V. What is the problem?
transformer with ct or non ct? galih Chip Amps 7 7th December 2009 05:08 PM
Missing 6.3V CT/'Cockeyed Bridge' problem pjanda1 Tubes / Valves 4 17th January 2009 03:50 AM
6.3v 30A!? imix500 Tubes / Valves 13 20th March 2004 11:09 PM
6.3V rectifiers.... Guiness Tubes / Valves 7 14th April 2003 08:24 PM
Page generated in 0.08879 seconds (80.05% PHP - 19.95% MySQL) with 11 queries
