Recommend a good plate choke for 26 tube!! Recommend a good plate choke for 26 tube!! - Page 3 - diyAudio
Old 16th March 2011, 11:51 AM   #21
andyjevans is offline andyjevans  United Kingdom
Originally Posted by vgeorge View Post
Andy,
I used ll1667 25mA with more than 200H inductance and cap output in my 26 pre.
Switching to ll1660pp 4:1 improved the sound considerably.
I' m using battery bias and Rod' s fillament supply.
I'm currently using a LL1660/5mA in 1:1 in my 26 preamp. I have filament bias right now but I could also use battery bias at some point - I tried that in my 10y preamp and it sounded fairly similar. Anyway, I'm loving the LL1660.
So I have a question for the 26 community. There are more choices in plate chokes for the 26 than there are in output/interstage transformers.
What is available besides the LL1660 in transformers? I can't think of anything obvious, and some builders of 26 preamps might want - for example - to consider the availability of cheaper transformers at the expense of a compromise (big or small) in sound. Edcor do a 15K:15K
Other builders may want something more sophisticated - nickel, amorphous etc.
Any ideas for transformers the 26 would be happy with? I'm guessing at least 150 Henries
Andy
Old 16th March 2011, 01:21 PM   #22
kevinkr's Avatar
On the vintage side both UTC HA-133 and UTC A-25 15K:600 work well.
Electra-Print will custom build OPTs for the 26/01 as well.
Magnequest made excellent 10K:600 and 20K:600 OPTs. (Both have sufficient primary inductance for use with a 26 or 01)
Hashimoto HL-20K-6 (20K:600) for 26/01
Hashimoto HL-10K-6 (10K) which is probably a better match for the 12/112 due to its primary inductance of 95H.
Sowter doesn't appear to make anything with sufficient inductance for use with a 26.
AE might be persuaded to custom make an appropriate transformer, but does not appear to offer anything directly suitable.
In the Lundahl line the LL1660/10mA appears suitable when configured as a 4.5:1 step down.
Bartolucci line stage models A, B and F could also be used. (While my experience with Bartolucci is limited, the few I have worked with were excellent.)
Trafomatic may also make suitable transformers, but lists none on their site so they would have to be contacted. (They also make excellent transformers)
Iso Tango NP-126 may be suitable, no idea what the primary inductance is however.
James, and Tamura would be other likely sources as well.
None of these are particularly cheap either...
Edcor (a custom type, not OTS) or Electra-Print are likely to be the most economical choices.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 16th March 2011, 02:55 PM   #23
Wow!! That's really useful. I'm shooting for 1:1 and short leads to the amp, or even put the first stage in the amp itself, simply because I only use DHTs with low mu and so gain is too precious to sacrifice. I know Thomas and yourself and conventional practice favour stepdown and higher mu tubes in the amp, but that's not the application I need here, which effectively is an interstage. I'm probably happy with the LL1660/5ma but I'm really curious about alternatives.
This may then be a question of a custom made unit if it's 1:1 since most of the above list are 600 ohm output. You wouldn't normally use a 26 as a driver, so interstages rarely go up that high in Henries.
You can't help getting a bit excited at the Japanese exotica, though....... Mmmmm. But as you say, expensivo.
Andy
Old 16th March 2011, 03:13 PM   #24
Sheldon is offline Sheldon  United States
Dave Slagle, who posts here sometimes, also makes custom chokes and transformers. Made some massive chokes for a 801 parafeed amp of mine. They measure and sound good.
Sheldon
Old 16th March 2011, 03:24 PM   #25
kevinkr's Avatar
Sheldon
I'll second that, don't know how I forgot Dave...
Old 16th March 2011, 05:11 PM   #26
Vinylsavor is online now Vinylsavor  Germany
Vinylsavor's Avatar
Hi!
For interstage, the Tango NC20F works nicely. Although it has surprisingly low inductance I got excellent results with it, especiaqlly in the bass. It is very expensive but among the best interstages available today and worth it's cost
Thomas
http://vinylsavor.blogspot.com/
Old 16th March 2011, 08:46 PM   #27
Hi Thomas,
Did you use the Tango with a 26 tube?
Andy
Old 16th March 2011, 10:09 PM   #28
Vinylsavor's Avatar
Hi Andy,
yes I used it with a 26 in this amp:
VinylSavor: Making of an 45 / 2A3 amplifier
Thomas
Old 17th March 2011, 12:40 AM   #29
Hmmm. Interesting. I was thinking 150H was the minimum for a 26.
I just hooked up two 156C Hammonds in series as plate chokes. Twice 150H should give 300H I assume. Sounds remarkably pleasant for a cheap solution. Doesn't quite have the magic of the LL1660 which is a bit special, but nevertheless the sound is all there - clean and clear. I used battery bias. Output caps were Teflon FT-3. I'll also try some Russian 0.1 silver mica when I can. Haven't compared those directly and that would be worth knowing.
andy
Old 17th March 2011, 08:19 AM   #30
Vinylsavor's Avatar
Hi Andy,
all Tango Transformers have surprisingly low primary inductance for the intended applications yet sound remarkably good, especially in the bass.
Generally I also prefer to have higher inductance. Especially in the linestage I want the roll off not to start too early.
I also like the LL1660 a lot. Although it really sounds best in 4.5:1
If you don't have to adjust your volume pot all the way up for average listening and have some margin in gain, I do encourage you to just try this. It is just a few solder joints and reversed in a few minutes. I'm sure you will be pleasantly surprised! See I try hard to convert you on this point
Coming back to the NC20: This one is sound wise in another league alltogether! However just 1:1, so only for interstage use.
As step down transformers I also tried Tango NP8. Here I clearly prefer the Lundahl 1660/4.5:1! Even in my most elaborate directly heated linestages I use the Lundahl.
Best regards
Thomas
Recommend a good plate choke for 26 tube!!Hide this!Advertise here!
Hammond 156C - good Plate choke load?? kmtang Tubes / Valves 12 3rd August 2012 08:07 PM
Plate Choke SRPP…. What do think? sgerus Tubes / Valves 22 20th January 2009 08:18 PM
PP plate-choke? revintage Tubes / Valves 4 28th June 2007 11:59 PM
using a plate choke? Raj1 Tubes / Valves 15 5th June 2005 07:36 PM
Any good #26 line amp designs? Burnedfingers Tubes / Valves 20 27th October 2003 11:36 AM
Copyright ©1999-2017 diyAudio
