High-End preamplifier with ECC82!
Old 25th February 2011, 07:14 AM   #1
radio is offline radio  Macedonia
Banned
Default High-End preamplifier with ECC82!
Hello!
The measurements refer to the preamplifier is given below in Scheme (Figure 1)!
Please someone let that little comment about this preamplifier, if it does as a power preamplifieramplifier.
Feedback to be about the sound and display measurements if it worked.
If someone izradijo this pretpoačalo and made some measurements and some show here (frequency response and attitude towards the second and third harmonic!!?)
Many thanks in advance!
File Type: png ECC802S-12AU7-ECC82-Tube-Preamplifier-Schematic.png (21.8 KB, 3817 views)
Old 25th February 2011, 07:49 AM   #2
revintage is offline revintage
This is absolutely not "High-End"!
Old 25th February 2011, 08:14 AM   #3
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
Why not ? For best implementation of that circuit , octal tubes such as 6SN7
could be used . Lower and upper tubes would need separate filament supply ,possibly DC regulated ,and the upper one needs also a reference to B+.
Major importance should be given to the power supply section ...which 'sounds' and can be detected as the 'line preamp' circuit .
http://www.webalice.it/jlc891/schemiprechf43.htm
Old 25th February 2011, 12:05 PM   #4
Alastair E is offline Alastair E  Wales
Alastair E's Avatar
Nah, Personally--I dont like it!
Be better to do a Proper Mu stage, maybe with mosfet on top or a Pentode....
Dont like the ECC82 either, Nasty little things IMO....
Old 4th April 2011, 11:10 AM   #5
Banned
Thumbs up High End preamplifier with ECC82-Circuit!!
Hello All !
I'd recommend a scheme (circuit) for the "High-End Preamplifier with ECC82" or ECC83
Old 4th April 2011, 01:18 PM   #6
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
It's kind of easier to recommend circuits without ECC82 or ECC83
Old 4th April 2011, 01:40 PM   #7
GoranB is offline GoranB  Poland
GoranB's Avatar
Originally Posted by radio View Post
Hello All !
Here is one, maybe not High-End but with ECC 82 as you wanted.
Pozdrav zemo
Old 4th April 2011, 03:22 PM   #8
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Why bother a tube preamp your source is also solid state.
Only use of tube pre-stage is for a turntable IMO, then from source there is no solid-state involved.
And in when stage the tube preamp design becomes high-end?
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 4th April 2011, 03:37 PM   #9
Evenharmonics is offline Evenharmonics  United States
When the price gets high.
Old 4th April 2011, 03:40 PM   #10
Cassiel is offline Cassiel  Libya
Why bother with tube amps at all if the source is not a a turntable?
ECC82's can sound good in a mu follower topology, I can post a schematic if you're interested.
High-End preamplifier with ECC82!Hide this!Advertise here!
Is high-end audio just lots of gimmicks and high price tags ?? Trevor White Everything Else 497 20th June 2011 10:07 PM
Hi-end phono preamplifier quanghao Quanghao Audio Design 8 30th June 2010 03:37 AM
High End Preamplifier hadihf Chip Amps 15 10th August 2008 09:40 PM
FS : Car tube preamplifier (ECC83 + ECC82) ANALOG GUY Swap Meet 0 21st June 2006 03:57 AM
high end version of low end phono stage dsavitsk Solid State 20 1st September 2005 11:51 PM
Copyright ©1999-2017 diyAudio
