Little help needed / do I have a bad tube or really good tube? - Page 2 - diyAudio
Old 24th February 2011, 04:14 PM   #11
JHelms is offline JHelms  United States
Thanks guys. I will have this tube tested today and see what they say, I am not complaining at all about it as it sounds fantastic even in this little amp. It just behaves so different than my other tubes and was just looking for some insight on to the possible reasons.
Also my headphones are... 150ohm and the second set is 300ohm.
Old 24th February 2011, 04:56 PM   #12
The changes I have made are as follows...
- Changed the stock irf630's with irl530's
- Changed out the fixed 3K resistors at r13 and r14 with 5K pots
- Changed the stock 6800uF 25V at c7 to a 4800uF 35V as it did not make much sense to run a 25v cap on 24V input
- Changed out the two 1000uF 85C caps to 105C 2200uF at c4 and c5 since one of the units is right next to a scalding hot lm317
- Cut the traces between pin 4 and 5 as the filaments are connected which was the cause of a ugly crosstalk problem. Pic below shows the issue, cut traces in red and jumper wire in blue taken from rock grotto
Old 24th February 2011, 05:24 PM   #13
kevinkr's Avatar
Wow, you've done all the right stuff. I would however add a small resistor in series with the CCS pots to avoid saturating the CCS.
Things to try would include increasing the value of R4 and R5 to make the grid current work for you, this could develop some real grid bias. Anything up to 1M might be worth trying, but I suspect the optimum resistance value would probably be a couple of hundred K ohms at most. Cathode bias would be another thing to try with small resistance values..
You could try a 6GM8 with a minor revision to the filament wiring, but I suspect based on your comments about cross talk a largish cap across the filament would be required as well. So maybe that isn't the brilliant idea I thought it was..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 24th February 2011, 07:28 PM   #14
Well the mods I cannot take credit for, the guys over at rock grotto came up with them. I just can sling solder quite well so followed their lead
They mentioned a 1K resistor across the pots but I did not know exactly what it was doing / they said it was optional so did not include it. You think it is a good idea then? I will add those in when I get a moment.
Only one major thing left, Need to isolate hum in the unit. It is present with any tube but goes away when I touch anything on the unit that is groun or if I touch any ground on the unit with a wire that is connected to earth. I assume it is being caused by the cheapy switching power supply they included.
Old 24th February 2011, 07:48 PM   #15
My little budget gem with the jj gold pin glowing away.
Old 25th February 2011, 03:13 PM   #16
Ok picked up another JJ 12au7 gold pin yesterday, same as the one I felt that biased strange / but sounded awesome! And the results? Same as the first! Cannot get it much below 16V but the right channel I had to raise the voltage a little to get it to match. Sounds identical to the first unit so I am very happy. Great little tube!
Crinkly tube getter Is this bad? Pyre Tubes / Valves 7 28th February 2014 12:02 AM
Speakers not connected on tube amp, good or bad? s2kov Tubes / Valves 20 30th July 2013 10:33 AM
suspect a bad tube-any simple checks? fenderjazz Tubes / Valves 16 25th December 2010 07:08 AM
Tube flashes on tester... Bad ? ThSpeakerDude88 Equipment & Tools 14 11th January 2008 02:09 PM
Bad tube? jogas Tubes / Valves 13 8th May 2005 06:32 PM
Copyright 1999-2017 diyAudio
