diyAudio Sponsor
Old 23rd February 2011, 11:38 PM   #1
ryuji is offline ryuji  United States
Default 5.1 channel 807 SE amplifier
I just finished my project after a few months of planning/assembly but mostly waiting for parts to arrive in mail. Decided to share.
Design:
The amplifier has five 807 pentodes running in single-ended fixed bias with Edcor GXSE10-8-5k output transformers. the pentodes are driven by 12AT7's. in addition, i have made use of 12AU7's as pre-amplifiers for all 5 channels, plus a sub-woofer pre-amp for a external solid state amplifier. I am making use of an 5C8S rectifier tube for the 320ma of current required for powering so many channels. The power transformer is a Antek AN-4T400 which is rated for 400VA. The VR-105 tubes are wired in series and used to provide regulated power for grid 2 on the pentodes. Filaments are powered by a modified random pc power supply i tweaked to provide 12.6v
Pictures:
I have pictures i have taken as i built it. Can take more pictures/better pictures of certain parts if people are interested. more pictures can be found at:
ryuji's pictures
Schematics:
I used multiple schematics to build the amplifier:
Power tube design:
Pre amp:
Bias supply:
Additional information about anything available by request
Old 26th February 2011, 06:07 PM   #2
807tubenut's Avatar
Wow nice work!
All my battles have been won, But the war has just begun.
G-807=807 SE or PP? gabrielbecheanu Tubes / Valves 8 18th July 2010 11:57 PM
How much power for a SE 807 amplifier? Original Burnedfingers Tubes / Valves 26 3rd November 2009 01:38 AM
Simple SE with 807? dogfish Tubes / Valves 19 24th September 2009 04:23 AM
Se 807?? Sparky OR Tubes / Valves 1 31st December 2007 04:48 PM
Page generated in 0.07023 seconds (71.57% PHP - 28.43% MySQL) with 10 queries
