does tube bias drift like silicon devices
Old 23rd February 2011, 09:35 PM   #1
tryonziess is offline tryonziess  United States
Default does tube bias drift like silicon devices
Considering using 10 output tubes per channel in an amp build I was wondering if the bias drifts in a tube like it does in a solid state device.
With a bias pot per pair of output tubes the adjustment should be pretty close to where you want it for each two tubes in the output if things do not drift too terribly bad. I know that solid state transistors sometimes need to achieve temperature equilibrium to get an accurate bias setting. Do the tubes act the same way or can you expect the bias to stay put.
I really do not wish to install a servo bias adjustment circuit. However, if needed then so be it.
Tad
Old 23rd February 2011, 09:49 PM   #2
jcx is offline jcx  United States
tubes don't just do the long warm up offset/operating point drift with temperature - they also "age"/wearout
where Si devices mostly do the same thing for decades once packaging/constrution stresses stabilize after a number of thermal cycles
depending on power level, derating, tubes may need rebiasing several times a year and eventually can't be made to work at all
does tube bias drift like silicon devicesHide this!Advertise here!
Bias Drift AmpBuilder225 Tubes / Valves 9 4th November 2009 04:38 PM
Strange bias drift while cooling ceharden Solid State 4 12th April 2009 11:38 AM
Tube regulator for solidstate devices thomsva Tubes / Valves 6 13th May 2007 01:35 PM
Substituting tube rectifiers by silicon Valvomaniac Tubes / Valves 24 9th April 2007 02:13 AM
silicon or tube rectifier? felixx Power Supplies 5 4th October 2006 01:43 PM
Copyright ©1999-2017 diyAudio
