diyAudio Sponsor
Old 22nd February 2011, 01:08 PM   #1
Default REN904 for linestage?
REN904 (or similar) is an audio triode specifically made for transformer coupling. Would it be a good candidate for a linestage with a 30k:500 line output transformer, you think? The gain is approx 30x.
Vf 4
Af 1
Va 250
Vg -3.5
mAa 6
ra 12,500
gm 2.4
Thanx!
Old 22nd February 2011, 01:42 PM   #2
kevinkr's Avatar
Plate resistance is pretty high for use with full audio bandwidth transformers, building a 30K transformer that is reasonably flat over a range of just 20Hz - 20kHz would be very difficult.
Tubes with an rp half that of the REN904 or less would be much easier to source a transformer for.
www.kta-hifi.net
Old 22nd February 2011, 02:08 PM   #3
[QUOTE=kevinkr;2478657)
Tubes with an rp half that of the REN904 or less would be much easier to source a transformer for.[/QUOTE]
In my experience tubes with an Rp around 6-7k (6SN7 for instance) are about the limit with inductive coupling. Plate chokes and dedicated 1:1 transformers will do, but everything else becomes problematic. The combination of high Rp and winding capacitance will result in loss of treble and/or early HF phase shift.
Old 22nd February 2011, 02:34 PM   #4
Bartolucci has a 30k/1200 transformer. Have look at type F here.
Data seems to be good.
Ricerca e Sviluppo - Bartolucci Transformers - Products List - Preamplifier OPTs
Thanx!
Old 22nd February 2011, 03:26 PM   #5
Bequerel,
Data of this transformer seems to be good, but in what regard?
It has some 240H of inductance, needed for bass response.
Frequency response is indicated to be -3 dB at 10 Hz.
But the problem, without doubt, will be "at the other side" of the spectrum.
Don't expect audio treble with a 12k Rp tube; we can't cheat nature.
Old 22nd February 2011, 03:33 PM   #6
Originally Posted by pieter t View Post
Bequerel,
... we can't cheat nature.
No, you are sure right about that.
Thanx!
Old 22nd February 2011, 04:40 PM   #7
Vinylsavor's Avatar
Hi!
Agree to the comments above. In addition:
To my taste the tube would not have enough headroom for linestage duty, especially if the volume control would be placed at the output.
Do you really need that much gain in a linestage?
Thomas
http://vinylsavor.blogspot.com/
Old 23rd February 2011, 06:39 AM   #8
Originally Posted by Vinylsavor View Post
Hi!
Thomas
With the Bartolucci transformer the gain would have been approx. 6.
But I agree, you usually do not need that much gain either.
Thanx!
C3M linestage costa23 Tubes / Valves 15 23rd August 2009 08:53 AM
SRPP linestage help DoomPixie Tubes / Valves 7 5th July 2005 02:49 PM
Another linestage...... kianbach Tubes / Valves 11 28th June 2005 05:34 PM
linestage needed kmj Tubes / Valves 8 10th May 2004 11:16 PM
Page generated in 0.09763 seconds (77.54% PHP - 22.46% MySQL) with 10 queries
