| diyAudio Sponsor | ||
Why the 6SN7 attached to the power supply?
#2 |
#3 |
Complex of a citizen of once industrial country
#4 |
#5 |
Also, 300V half-wave rectified cannot possibly feed a 330V zener regulator
Never send a human to do a machine's job. --Agent Smith |
#6 |
It's a mini regulator. Bogen used the same thing for their screen regulators on some amps. The SRRP suffers from poor power supply ripple rejection so it could be a useful application of the regulator.
#7 |
Looks like a kind of active bootstrap current source - it takes a signal from the cathode of the lower tube and since the cathode resistor is not bypassed it samples the signal.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#8 |
My guess is a bootstrap voltage source, in order to reduce distortion? It won't improve PSRR, but probably make it worse by directly injecting HT noise into the input cathode.
300V RMS AC half-wave rectified gives 420V, so plenty to drive a 330V zener chain. |
#9 |
Odd! It does seem the lower 6SN7 is driving the upper one. But it's the opposite phase of a typical voltage bootstrap. It lowers the plate voltage on the middle 6SN7 plate when the signal is rising toward +. Since the effect would be small: 1/Mu, thru the plate, I can only guess this is some scheme for affecting distortion. Notice the same size cathode resistors on the lower two 6SN7's. Simulation needed. Could maybe replace the topmost 6SN7 with a Mosfet for convenience.
Ohms Law V = I R |
#10 |
| I found more junk! | Magnetmaz | Tubes / Valves | 9 | 28th December 2007 08:49 AM |
| New Chip Junk | classd4sure | Class D | 85 | 20th September 2006 08:24 PM |
| Just got new junk from my friend | Giaime | Solid State | 29 | 22nd March 2005 12:29 PM |
| got some interesting junk | yosh | Parts | 2 | 27th June 2004 09:01 AM |
| Page generated in 0.10535 seconds (76.35% PHP - 23.65% MySQL) with 11 queries |
