diyAudio Sponsor
Old 20th February 2011, 11:51 PM   #1
prb123 is offline prb123  United States
Default Sound Valves vtp-101 Schematic
Does anyone have a schematic for a Sound Valves vtp-101 pre-amp?
Mine is blowing fuses immediately on start-up. It looks like I'll have to remove the front knobs, then the faceplate then can pull the board to troubleshoot (plus I have to be careful of the wiring to the phono jacks)...so I'd like as much info as possible before starting.
Thanks in advance,
Pat
Old 8th May 2011, 10:30 PM   #2
I am looking for a schematic for the vtp 101 also My preamp has hum and several caps are bad for sure .Did you ever find a schematic
Old 30th November 2011, 03:40 PM   #3
heyraz is offline heyraz  United States
I've also been looking for a VTP-101 schematic as I would like to beef up the power supply. In the meantime, my unit recently developed a slight hum and finally blew it's fuse last week. All the high voltage electrolytic caps showed evidence they had leaked, which I think eventually caused the bridge rectifier to blow shorted, which blew the fuse. I replaced all of the high voltage electrolytic caps other than the 3 cans and the bridge rectifier with a 4A 400V BR (orig was 2A 50V). As I noticed the main board showed evidence of excessive heat below the BR, I raised the new BR up 1\2" on it's leads to allow it to radiate better. I also replaced the wires from the phono inputs with 24G solid twisted pair (original appeared to be 20G stranded) and replaced the 2.2uf 160v MPK output coupling caps with 2.0uf 200v Sprague Vit Q PIO's. After the PIO's broke in, the sound really opened up an became more transparent. Very satisfied with the PIO's. Next I plan on changing the cheap vol pot to a higher quality stepped pot.
Please let me know it you ever came across a schematic. Thanks. Rich
Old 5th December 2011, 05:03 AM   #4
sso is offline sso  United States
Default Schematic
I just bought a VTP-101 last week. It was a copy of the very rare Dynaco PAS-3 Series II.
PM me I can send you a copy of the manual.
Roy at tubes4hifi knows everything about every Dynaco products. You should have a chat with him.
Stan
Hafler parts - Sound Valves? DMF Solid State 21 24th March 2010 08:12 PM
valves dont sound so good when pink.... adamus Tubes / Valves 2 2nd October 2009 09:58 AM
Searching Sound Valves M40 Monoblocks schematic echo_airiti Tubes / Valves 2 25th January 2008 01:32 AM
sound valves m-40 schematics 11ongas Tubes / Valves 3 10th February 2007 11:20 PM
Sound Valves M-40 assistance audioquestM-40 Tubes / Valves 3 20th December 2005 05:46 PM
Page generated in 0.07460 seconds (71.75% PHP - 28.25% MySQL) with 10 queries
