diyAudio Sponsor
Old 18th February 2011, 06:41 PM   #1
Tyimo is offline Tyimo  Hungary
Default Pi wound output transformers
Hi!
I read many nice thing about Pi wound output transformers.
I know that Pi wound transformers are 100% symmetrically balanced and have 2X greater high frequency response than a conventional layer wound output transformers.
Pi-winding helps to breakup series resonance at high frequencies. etc.
Does anybody have experience with this technique?
Is it realy works?
greets:
Tyimo
Old 18th February 2011, 06:53 PM   #2
Originally Posted by Tyimo View Post
Hi!
Is it realy works?
greets:
Tyimo
When you know why do you ask if it works?
Old 18th February 2011, 07:04 PM   #3
Knarf is offline Knarf  Denmark
Knarf's Avatar
It certainly works for tuning coils used at lower radio frequencies, like 100KHz-1MHz. By using a pie wound (not 'pi') coil, you reduce the parasitic capacitance across the coil for a given physical size, thus increasing its quality factor, Q. This is very important in many radio application, like when trying to make sharp bandpass filters.
Whether this makes any difference in audio transformers I cannot say...
Team Thermionic
Old 18th February 2011, 07:07 PM   #4
I know where the "information" comes from.
As long as the claim is not backed up by reliable measurment with an audio transformer, it does not make sense.
The site has useful info and a bit of nonsense anyway.
Old 18th February 2011, 07:08 PM   #5
I know it unfortunately only theoretically...
And please, just smile!
Old 18th February 2011, 07:11 PM   #6
For example from here:
Lenard Audio - Education - Valve Amps
Old 18th February 2011, 07:14 PM   #7
Yeah Tyimo I know.
What I said, some useful information but also some nonsense (the cathode bias classA for instance).
Old 18th February 2011, 08:03 PM   #8
Personally I prefer toroids. Unlike many contrary beliefs, it is not a problem to design and build audio output toroids which don't suffer from core saturation caused by DC imbalance of output stage idle current.
I have a pair of 60W 5K PP toroids which can sustain 15 mA imbalance at 36W/20 Hz (lover frequency = higher flux density). I didn't tested them yet at full load, need to build power resistor network first.
Many people are obsessed with exotic techniques, but simply put, this is not necessary. Its possible to build excellent transformer with either EI, Double C, or toroid. The rest is up to availability of material and price.
Output transformers hrnous Tubes / Valves 8 22nd April 2010 08:08 PM
Difference between SE output transformer and push-pull output transformers hilbert_mostert Tubes / Valves 12 8th March 2009 05:10 PM
Help identifying a pair of output transformers and power transformers mjk130 Parts 3 30th January 2009 10:44 AM
How are torroidal transformers wound malloryn Parts 4 7th April 2004 07:36 AM
Home Wound Audio Transformers G-Daddy Multi-Way 1 4th November 2001 02:10 AM
Page generated in 0.10509 seconds (78.52% PHP - 21.48% MySQL) with 10 queries
