Physical Oscillating noise from phono stage - diyAudio
Old 17th February 2011, 10:06 PM   #1
Eric W is offline Eric W  United States
Default Physical Oscillating noise from phono stage
Hi Everyone.
I have an old Harman Kardon Trio tube that sat on a shelf for around 5 years. Everything worked fine at that point. Now there is a physical sound coming from the amp when i switch it over to the phono stage. As in an audible sound the amp itself makes, when not connected to any speaker. It sounds like an oscillating something. It starts at a frequency, then shifts until it reaches a balancing period/frequency and then stays at that level. I'm just wondering where I should start looking. The tubes, an old cap? I'm not even sure what you would call this noise in order to try finding out about it online.
Thanks.
Old 17th February 2011, 10:22 PM   #2
I forgot to say that if a test driver is used, then the noise is amplified and the driver is pushed past any decent limit.
Old 17th February 2011, 10:46 PM   #3
SY's Avatar
Both channels or just one?
Have the electrolytic filter caps been replaced? Tubes?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th February 2011, 11:03 PM   #4
I believe, but am not positive, that the tubes were replaced about ten years ago. I haven't done a lot of heavy vinyl listening since then. I don't think the caps have been changed. The amp works great in non phono stage setups.
I just noticed that the oscillating lazer like noise either goes away, or becomes much quieter when you connect a driver to the left channel, but continues if you connect the right. the driver then starts to sound like a cheap machine gun toy.
Old 17th February 2011, 11:37 PM   #5
SY's Avatar
What test equipment do you have? Voltmeter? Oscilloscope?
The likelihood is a decoupling electrolytic for the phono stage (they should all be replaced anyway). I don't have a schematic handy, but if your phono stage has any tubes which are common to both channels, that would be a suspect as well.
Old 17th February 2011, 11:53 PM   #6
I believe a friend of mine has a voltmeter and an oscilloscope. He has a couple solid state amp projects going now, but no experience with tubes. I'll replace the caps and see if that solves the issue.
Old 18th February 2011, 12:05 AM   #7
SY's Avatar
Cool, if that doesn't do the trick, come on back and we'll go through it systematically.
Old 18th February 2011, 02:32 PM   #8
kevinkr's Avatar
The one thing no one has mentioned is to never run a tube amp without a load either resistors or speakers. Given that it is generating large amplitude LF pulses running unloaded is an excellent way to consign the output transformers to the scrap heap.. (Flyback effect)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Difference between self oscillating and non-self oscillating D-amp. sildex Class D 36 4th August 2010 04:30 PM
Stage output, driver oscillating Rafael L Solid State 20 19th May 2009 08:31 AM
DIY phono to replace roksan phono stage seroxatmad Analog Line Level 6 14th December 2008 06:46 PM
new phono stage or old preamp with phono? flohmann Analog Line Level 2 2nd October 2008 10:51 PM
Should I replace Scott 222C phono stage with Claret phono stage? Bing Yang Analogue Source 0 22nd August 2005 07:41 AM
Copyright 1999-2017 diyAudio
