One more 4P1L SE - Page 68 - diyAudio
Old 15th November 2013, 10:40 AM   #671
Default Circuit
Circuit ... try again ...
Old 15th November 2013, 01:35 PM   #672
stajo is offline stajo  Sweden
Nice IP. On a 1660 with primarys in series I might even try UL.
Old 16th November 2013, 01:24 AM   #673
Pano is offline Pano  United States
Pano's Avatar
I'm still using the 4P1L triode strapped to run my horns. Battery bias, single 6SN7 input with LED bias. Nothing changed at all. I'm happy.
http://www.diyaudio.com/forums/showthread.php?p=3400631
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 16th November 2013, 03:03 AM   #674
Here is my favorite amp, very simple, easy to build, quite cheap, output ~ 3W, deadly quiet with noise 0.6-0.8mV. Sound is so sweet and It beats my 300B on midrange
Old 16th November 2013, 04:21 PM   #675
Could you clarify the impedences on the primary of the output transformer? Is it
3.5k on each primary or 1.75k adding up to 3.5k? I haven't seen separate coils
used to achieve what looks to be an ultralinear setup. Very interesting,
Thanks for posting this,
Skip
Old 17th November 2013, 01:33 PM   #676
These opt are diy product from a friend. Plate and g2 winding are the same turns and have same 3.5K impedance. I guess it operates like something between triode and ultralinear, so I can get more power than one in triode.
Old 17th November 2013, 06:42 PM   #677
Pano's Avatar
Interesting. It looks like one winding of the primary is simply acting as a feedback loop.
Old 17th November 2013, 06:52 PM   #678
Feedback? Its a normal 50 percent between pentode and triode to me. Ultra linear concept. Evolve plz
Edit. I see now, its on G2. Sorry. Yes please?
Old 17th November 2013, 06:55 PM   #679
Pano's Avatar
Yes, and that's a form of feedback, right? Ultra-linear is usually at 43% tap, that's all.
Old 17th November 2013, 07:01 PM   #680
yagoolar's Avatar
Send a message via ICQ to yagoolar Send a message via Skype™ to yagoolar
If two windings were in series and its center point were connected to G2 it could be UL, but they are in parallel.
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
