#561 |
#562 |
signal source
dac pcm63p NOS round wire potentiometer 25 ohm.for i / v converter and volume control PC900 triode with plate choke ![]() ![]() AZ1 power supply channels individualized rl
#563 |
#564 |
Very nice work! Did you build your speakers yourself? They're really something.
Andy |
#565 |
#566 |
#567 |
Brilliant!
#568 |
I am a bit glad speakers came up, for as much info on SET amps there is very little info on this site for modest high efficiency speakers, what are people without cad assisted machines doing for speakers. Are something like econo waveguides a good route to take for and amp this small powered. I have a pair of BR Fostex 127E but they just don't have any bass, I don't know where to look for info on modest budget horn setups.
#569 |
For those interested in simulating their designs with SPICE, I developed a slightly refined DHT composite model using my own set of curves. A model is available for PSE as well.
Difference is on KP parameter which drives linearity of the model. With Dmitry's model you get a slightly worse THD response when swinging the 4P1L to its limits. 4P1L triode SPICE model | Bartola Valves Hope this helps Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp) http://www.bartola.co.uk/valves/ |
#570 |
Thanks Ale. As I mentioned before, if you ever find the time to trace the 26 would be great. Dmitry's model of the 26 I think is based on the datasheet, not a working sample.
| pentode in triode mode SE vs a DHT SE like 2a3/300b | jarthel | Tubes / Valves | 62 | 1st January 2013 09:14 PM |
| Russian-English Translation of 4P1L datasheet | 316a | Tubes / Valves | 16 | 6th September 2011 12:09 AM |
| Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). | mik190 | Swap Meet | 7 | 1st November 2010 07:59 AM |
| Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? | nelsondog | Everything Else | 1 | 11th November 2007 05:00 PM |
| Parallel SE vs. Single SE Output Question | valveitude | Tubes / Valves | 19 | 4th May 2005 05:36 PM |
