One more 4P1L SE - Page 40 - diyAudio
Old 13th January 2013, 01:07 PM   #391
Pano is offline Pano  United States
Pano's Avatar
Ale, you're killing me! I wanted to be in there first with the 4P1L pentode driving the 4P1L in triode mode. Alas, it took a month for my tubes to arrive, then I was out of town for a week. Grrr.....
So I'll be following in your footsteps on this path.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 13th January 2013, 01:52 PM   #392
Originally Posted by mogliaa View Post
Improved Pentode driver by adding a parallel resistor to the gyrator output and managed to halve distortion: THD=0.27% @ 200Vpp, 4P1L is a great driver candidate indeed!
4P1L Pentode Driver (Test 2) | Bartola Valves
Ale
what is the gain of Pentode driver 4P1L? Operation point is 256V/-3.6V?
Old 13th January 2013, 02:13 PM   #393
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
close to 150...
@ Pano, I just did some test, you can take it from here...
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 13th January 2013, 03:54 PM   #394
Pano's Avatar
I will, Ale, I will. This week.
Thanks for the gain info in pentode mode. Far more than I'll ever need to drive the output stage.
Old 13th January 2013, 04:06 PM   #395
mogliaa's Avatar
Good, keep us posted!
Gain is determined by the RL in parallel with the 4P1L when loaded with the gyrator (or CCS). It may be a bit high, you can reduce it by reducing the RL, but distortion will increase...
Ale
Old 13th January 2013, 06:04 PM   #396
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
Hi Anatolij and others.
Trying to find a cheaper, but good, pentode driver as a replacement for my existing C3g, Im here.
Based on Anatloij first post in this thread I simulated this 4P1L pentode driver. Works good to me.
I have no experience with 4P1L or another DH pentode. My plan is connect pin 1 and 7 to 4.2 Vdc then LED string from pin 8 to ground.
Correct?
Thanks to Ale for very good 4P1L pentode spice model.
Rajko
Old 13th January 2013, 07:05 PM   #397
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
Hi Raiko;
looks doable, except I personally would reconfigure your CCS into gyrator, for better regime stability of anode voltage.
The Devil is not so terrible as his math model is!
Old 13th January 2013, 07:13 PM   #398
RajkoM's Avatar
Originally Posted by Wavebourn View Post
Hi Raiko;
Tnx Anatolij
Old 14th January 2013, 12:04 PM   #399
Pano's Avatar
Lightbulb Max Voltage?
I'm having some trouble with my PSU. Trouble is the B+ voltage is too high (I think). Even with 80mA of draw it's up over 300V. Unloaded about 320V.
How high a voltage can the 4P1L take? I was thinking not going above 250V on the B+.
Still working with it, trying to insert some R into the line to drop the voltage. The series resistor would dissipate a lot of power. Maybe a 15W light bulb?
Old 14th January 2013, 01:06 PM   #400
palmas is offline palmas  Portugal
You should pay atention to the anode voltage, 250V should be OK.
The B+ you can have much more (400V, 500V...) depends on the anode resistor or CCS or whatever you're using.
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
