One more 4P1L SE - Page 34 - diyAudio
Old 24th December 2012, 04:07 PM   #331
regal is offline regal  United States
That's what I a using it is actually representing a pair is parallel. Oddly he doesn't give a single model.
Old 24th December 2012, 04:10 PM   #332
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
The pair are half-triodes, not two 4P1L in parallel
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 24th December 2012, 04:13 PM   #333
merlin el mago's Avatar
Originally Posted by Rod Coleman View Post
Hi Ale,
Yes, if the 47K grid resistor is moved to connect across the CCS only - then connect one end of the IT secondary to the bias, the other end to the grid. No other connexions at the grid needed.
This way, the grid sees the bias voltage, but the IT winding feels none of the dc current.
With a high quality IT, this will give an excellent solution!
Hello Rod,
Sorry my ignorance what's IT?
Old 24th December 2012, 04:18 PM   #334
mogliaa's Avatar
Hi Felipe,
It's an interstage transformer like the LL1671 used in my diagram
Feliz Navidad!
Ale
Old 24th December 2012, 04:24 PM   #335
mogliaa's Avatar
Hi Ale,
Cheers Rod, should have thought that one myself!
Here is the updated circuit, I think it should perform well and also can be easily tweaked to get the 4P1L output stage with a 20K grid bias resistor only...
Have a great Christmas!
Ale
Old 24th December 2012, 04:38 PM   #336
Originally Posted by mogliaa View Post
Hi Felipe,
Feliz Navidad!
Ale
Thanks Ale,
Merry Christmas to you too.
Felipe
Old 28th December 2012, 11:30 PM   #337
I just got around to doing some measurements of my 4p1l linestage,
20ma thru a single dn2540 and -12.4v @ 600ma using the phonostages 6e5p and 6c45pi's (shunted with 39r) heaters in filiment bias using coleman reg.
pretty happy for a newish project with lots of refinements available.
2nd harmonic at -85 db and 3rd -97
snr outside of the 50hz which i'm struggling to measure due to soundcard issues (noisy pc i think) is-100 to about 2k then -110+ up to the 40k i measured
and the bandwidth is about the same as my 192khz soundcard at half volume.
great tube!
Old 4th January 2013, 08:19 PM   #338
mogliaa's Avatar
I did some tests using the 4P1L as a driver in filament bias. Linearity is outstanding in triode mode as measured before, but was keen to see the performance in pentode mode. I tweaked my breadboard to run in pentode albeit it wasn't optimal but still got THD=0.58% @ 200Vpp which is really good for a driver!
4P1L Driver Tests | Bartola Valves
Old 8th January 2013, 06:07 PM   #339
Default No second ?
Just to throw in a thought after all the earlier discussion of 2nd harmonic and cancellation & which tube is more linear etc etc .
Why would you want to minimise all of the 2nd harmonic ? ;o)
If I had a pre-amp with 2nd harmonic at 70dB down, and one with no measurable 2nd-harmonic, I know which I would prefer !!
Old 8th January 2013, 06:22 PM   #340
Wavebourn's Avatar
Send a message via Skype™ to Wavebourn
No, you don't. Try first.
The Devil is not so terrible as his math model is!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
