One more 4P1L SE - Page 23 - diyAudio
Old 29th August 2012, 01:39 PM   #221
palmas is offline palmas  Portugal
Originally Posted by hihopes View Post
I've had my eye on these 4p1L's for some time now, and your endorsement has finally persuaded me to order some. I have 10 on the way. I want to build a SE preamp, then a simple as possible push-pull power amp with them. Can you recommend a good source for reasonably priced sockets for them?
William.
You can find a lot on e-bay, cheap and easy.
I'm looking foward to have the time to make a pre with these DHP.
Let me know how your's is doing.
Cheers
Old 29th August 2012, 02:54 PM   #222
You won't regret getting into the 4P1L. It's just amazing. Now - for a preamp it does have issues with microphonics. I'm OK because all my music is in my Mac Mini and the volume control is in software, so I don't need to touch the preamp at all. Bumps tend to set off microphonics and one way around this if you're going to be switching stuff or if you have a stepped attenuator which vibrates is to put the volume control and switch in a separate box and leave the preamp alone. Be sure to use filament bias!! It's all in the "26 pre amp" thread.
Andy
Old 29th August 2012, 03:34 PM   #223
Andy
The problem is I have a lot of other tubes to use for pre, and with some I'm half way in (10Y, 45, 211,...).
Will try to make a good pneumatic suspension for the 4P1L!
Old 29th August 2012, 03:37 PM   #224
Andy
Just one more detail: what is the expected gain from the 4P1L? I have a few Lundahl interstage to choose from and the decision will be based on the gain.
Old 29th August 2012, 09:11 PM   #225
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
Andy
I tend to slightly disagree here. I have successfully build a superb preamp with 4P1L and sound-wise I may say is even better that 26. A question of personal taste, still experimenting though now with a new version. Microphonics can be easily controlled: rubber suspension or suspended by cord. I have seen 30 preamps howling (not mine) and the 4P1L is really quiet. I got to a point that I needed to bang loud on the table to get a real impact on the 4P1L. Some 26/01a/112a, etc can be really microphonic, you have to select them by hand.
A lot of info about my experiments can be found on this long thread:
4P1L DHT Line Stage
cheers,
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 31st August 2012, 11:35 AM   #226
Default 4P1L as a pentode driver
Sorry this is a bit off topic, but has anyone actually tried using this as a pentode driver for an SE triode?
I have used pentodes to drive 45's and 2A3's before. I tried 6C6's and C3M's with regulated screen supplies driving 45's and 2A3's. Sounded good, but not as good as what I currently use, paralleled both halves of a 6N1P, LED cathode bias, 190V @ 14mA into a Hammond 126C IT driving a 2A3,.
I would like to try the 4P1L as a driver, but that means using another stage if I use the 4P1L in triode mode.
Would the 4P1L in pentode be a good driver for a 2A3? Anyone got any ideas about operating points with a resistive load?
Martin
Old 30th September 2012, 06:32 PM   #227
Default My PSE version
power: about 4W
sound: excellent, beter than GU50
Old 1st October 2012, 07:41 AM   #228
DimZ is offline DimZ  Greece
I think that 4P1L prices will rise ....... soon ....
Old 1st October 2012, 09:23 AM   #229
sure if we see post like this...!
Old 1st October 2012, 09:25 AM   #230
why not use 4p*....
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
