#121 |
Thanks!
![]() There will be also tubes for MM and MC phono stages (4 on top, 2 underneath) Phono input will be switchable between MM and MC. For MC will be used input transformers and 6S17K-V input tubes.
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. |
#122 |
#123 | |
"Extraordinary claims require extraordinary evidence." - Carl Sagan |
#124 |
I am working in parallel on 2x200W tube amp using GU-50 tubes.
![]() B+ will be 1 KV well regulated.
#125 |
I was fantasizing about the same 4gu50 tube PP. Although a 2 tube PP would look better I guess and 100W is only 3 db less than 200W.
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet Last edited by Helmuth; 18th March 2011 at 07:43 PM. |
#126 | |
Mine will be 250W limited by an optical peak compressor on 200w.
#127 | |
( (( KUGELWELLE )) ) recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet |
#128 |
#129 |
Yep, for a little bit higher number of listeners.
![]() Nice box! ![]() Here is one of my versions:
If I disappear suddenly, that means I finally created a time machine and pushed wrong button that brought me to Stalin's Russia. In any experiment any result is the result. Even if it is negative. Last edited by Wavebourn; 18th March 2011 at 10:51 PM. |
#130 |
Анатолий, amazing!!
| pentode in triode mode SE vs a DHT SE like 2a3/300b | jarthel | Tubes / Valves | 62 | 1st January 2013 09:14 PM |
| Russian-English Translation of 4P1L datasheet | 316a | Tubes / Valves | 16 | 6th September 2011 12:09 AM |
| Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). | mik190 | Swap Meet | 7 | 1st November 2010 07:59 AM |
| Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? | nelsondog | Everything Else | 1 | 11th November 2007 05:00 PM |
| Parallel SE vs. Single SE Output Question | valveitude | Tubes / Valves | 19 | 4th May 2005 05:36 PM |
