One more 4P1L SE
One more 4P1L SE
Old 14th January 2013, 01:25 PM   #401
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
300V should be fine... they tend to use conservative max ratings for long life.
Old 14th January 2013, 02:48 PM   #402
Pano is offline Pano  United States
Pano's Avatar
One more 4P1L SE
Thanks, I'll see what I can do with the PSU. As the DCR of the OPT is about 340R, there isn't much voltage drop at the anode. Easy to drop it at the input stage, not so easy at the output stage.
Old 14th January 2013, 03:00 PM   #403
iko is offline iko  Canada
iko's Avatar
One more 4P1L SE
Pano, you might want to throw in a tube rectifier if you haven't already. The voltage drop will help a bit. Also, consider a choke input ripple filter, instead of the capacitor input.
Old 14th January 2013, 04:32 PM   #404
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
I would use 250V Zener string and one source follower. Huge gain per buck.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 14th January 2013, 05:21 PM   #405
Pano's Avatar
One more 4P1L SE
Or I could make a gyrator/CCS out of some of the big depletion mode Mosfets I've got.
I am using a 6BY5G tube rectifier - a TV damping diode. I will get a choke in there ASAP. Thought I had one on hand, but seems not.
Old 14th January 2013, 05:52 PM   #406
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by regal View Post
Thanks for cleaning up my skimpy schematic, but 150V B+ is much too low.
Good operating point for this tube is 200-230V 30mA.
So that means you have a B+ of about 275V for the first tube with the CCS or gyrator, then use an extra RC to give the 200V B+ for the second tube.
I have 4 of the 4p1l's and am determined to build this when I finish this DAC B.S. But I am on the fence between Grados, Senns, and Orthos. So something to keep in mind when you buy your transformer is you might not want to be tied down to only a 300 ohm tap.
Also to add confusion if you read the ecp article linked above about parafeed, you will really get frustrated cause finding a permalloy core custom para-feed transformer is impossible.
A high quality permalloy 5k:300+32 parafeed OPT would be a real nice to have for preamp builders because it would give a nice headphone output. Kill two birds with one stone.
Can I use only one SSHV2 to power all four tubes? if yes have I to adjust SSHV2 to 140mA?
Old 14th January 2013, 06:00 PM   #407
stajo is offline stajo  Sweden
One more 4P1L SE
Originally Posted by merlin el mago View Post
Can I use only one SSHV2 to power all four tubes? if yes have I to adjust SSHV2 to 1440mA?
SSHV2 is good for about 100 mA
Old 14th January 2013, 06:05 PM   #408
Yes max current 100mA, so I will need two SSHV2 one for each channel, but the question is can I do it like the last attached pic?
Old 15th January 2013, 12:20 PM   #409
RajkoM is offline RajkoM  Bosnia and Herzegovina
RajkoM's Avatar
Anatolij,
How this gyrator will works in real life with 4P1L in pentode mode?
Sorry, I have no experience with the practical application of gyrator.
Thanks,
Rajko
Old 15th January 2013, 04:05 PM   #410
Wavebourn's Avatar
One more 4P1L SE
Hi Rajko;
I have no practical experience in loading pentodes on gyrators. :-)
But I believe that you will definitely need negative feedback, otherwise amplification will be excessive and frequency dependent. Like in opamps, where VAS stage is loaded on CCS.
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
