One more 4P1L SE
One more 4P1L SE
Old 12th January 2013, 12:52 PM   #381
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
One more 4P1L SE
Originally Posted by mogliaa View Post
I did some tests using the 4P1L as a driver in filament bias. Linearity is outstanding in triode mode as measured before, but was keen to see the performance in pentode mode. I tweaked my breadboard to run in pentode albeit it wasn't optimal but still got THD=0.58% @ 200Vpp which is really good for a driver!
4P1L Driver Tests | Bartola Valves
Improved Pentode driver by adding a parallel resistor to the gyrator output and managed to halve distortion: THD=0.27% @ 200Vpp, 4P1L is a great driver candidate indeed!
http://www.bartola.co.uk/valves/2013...driver-test-2/
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
Old 12th January 2013, 02:31 PM   #382
regal is offline regal  United States
Originally Posted by ikoflexer View Post
Using a 4p1l in the first stage but a 307A (triode connected) in the second stage gives you this. Not much of a difference. Of course, this is just simulation, not reality.
That looks really nice, unfortunatey the supply of the 307A is rather hit or miss I have often wondered if there was a russian equivilant. Any chance you could point us to the 307A model you are using ?
4P1L Pentode Driver (Test 2) | Bartola Valves
Ale
Is there an advantage of a DHT pentode, vs a 6c4pi ? I guess I always considered the little space tube as being a better driver.
Old 12th January 2013, 02:37 PM   #383
mogliaa's Avatar
One more 4P1L SE
Some will argue the sound of a pentode driver is better. I haven't tested the 4P1L pentode driver in filament bias, but it looks promising on the bench at least!
Ale
Old 12th January 2013, 03:34 PM   #384
Ale
For my 4p1l-4p1l idea it would be interesting to have a switch to throw the driver into pentode mode for low efficieny headphones that need more gain, or is the bias too different ?
Old 12th January 2013, 04:00 PM   #385
mogliaa's Avatar
One more 4P1L SE
When Listened to 4P1L-4P1L made me think I wanted a different sound, too clean perhaps :-)
Either way, you could bias driver on Vgk=-5V and operate the 4P1L in both pentode and tetrode with filament bias.
Old 12th January 2013, 06:08 PM   #386
Just check your website wow a lot of interesting new stuff.
I guess the next logical question would be does the 4P1L Pentode driver stage have the kuhnas to drive your 4-65a directly, making it a 2 stage amp instead of three stage could be beneficial ?
Old 12th January 2013, 06:45 PM   #387
mogliaa's Avatar
One more 4P1L SE
Thanks, I've been working a lot lately on my 4-65a Amp.
I thought about 4P1L as a driver, hence all the testing lately. eBoz used D3a in triode and others used pentodes. However, I already built the filament bias supply for the 46 and the 46 driver in filament bias (yes, hefty thing I know) is very promising....
Ale
Old 13th January 2013, 02:14 AM   #388
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Originally Posted by Wavebourn View Post
Some people believe that others prefer tube amps because of added distortions, despite experiments don't prove that. You can't model result of absense of nasty distortions adding something that is irrelevent. Like water from a glass cleaned by gasoline may look better than from glass cleaned by water that contained some clay, but it will not taste better. Adding to the glass of water cleaned by gasoline a bit of clay you can't improve it's taste.
best analogy ever
Old 13th January 2013, 02:14 AM   #389
4P1L is too clean, too much like SS. I like 26 better. (in my preamp)
Old 13th January 2013, 06:18 AM   #390
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
One more 4P1L SE
Hmmm... If SS was as clean as best tubes, why would I need tubes at all?
The Devil is not so terrible as his math model is!
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
