One more 4P1L SE
One more 4P1L SE
Old 10th January 2013, 06:22 PM   #371
iko is offline iko  Canada
iko's Avatar
One more 4P1L SE
Both tubes. Anything from 100R to 330R should be fine.
Old 10th January 2013, 06:33 PM   #372
merlin el mago is offline merlin el mago
merlin el mago's Avatar
I have 100R 1/2W, updated attached pic, the pic is OK now?
Old 10th January 2013, 06:50 PM   #373
IslandPink is offline IslandPink  United Kingdom
Originally Posted by Wavebourn View Post
No, you don't. Try first.
Hmmm... somewhat abrupt response ?
Yes well actually I do know which I'd prefer , because I was recently building a phono amp with various set-up options from a JFET/triode cascode on the front end . At the same time a good friend of mine built an exact equivalent of the set-up in a test rig and measured it with an Agilent spectrum analyser . It was very clear that the front-end sounded a lot better with some 2nd-harmonic at -70dB, than it sounded with the device set-up adjusted to give no measurable distortion.
I've had experiences that back-up this sort of conclusion in the SE amps I've built over the years plus measurements made on PP Class A DHT amps I built back in 2003 , where we used ( and tested ) it with and without the Western Electric 'harmonic equalizer' tweak .
The extent to which one would want some or no 2nd harmonic would be dependant on the system and the individual , but I agree that one should certainly 'try first' and also trust your ears . With 3rd and higher-orders, I think most people would prefer the lowest values you could get.
Old 10th January 2013, 06:59 PM   #374
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
One more 4P1L SE
It is actually what I meant. :-)
Some people believe that others prefer tube amps because of added distortions, despite experiments don't prove that. You can't model result of absense of nasty distortions adding something that is irrelevent. Like water from a glass cleaned by gasoline may look better than from glass cleaned by water that contained some clay, but it will not taste better. Adding to the glass of water cleaned by gasoline a bit of clay you can't improve it's taste.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 10th January 2013, 07:27 PM   #375
iko's Avatar
One more 4P1L SE
Roughly, this is how this simulates with the 4p1l model I have. No filament starving tricks here and operating points chosen in a hurry. Assumed 300mV p-p input, output 10V p-p, which for this circuits translates to about 90mW.
Old 10th January 2013, 07:33 PM   #376
iko's Avatar
One more 4P1L SE
Using a 4p1l in the first stage but a 307A (triode connected) in the second stage gives you this. Not much of a difference. Of course, this is just simulation, not reality.
Old 11th January 2013, 02:35 AM   #377
Pano is offline Pano  United States
Pano's Avatar
One more 4P1L SE
My 4P1L tubes finally came, but I've been too busy to do anything with them.
Next week is clear and I'll give it shot. Hope to have results and photos some time next week.
Take the Speaker Voltage Test!
Old 11th January 2013, 11:27 AM   #378
I'm not sure I fully understand your response , but I still think I disagree with you entirely ;o)
Of course we are not really talking about clay and gasoline here, it's about the fine balance of the first 3 or 4 distortion products in a SYSTEM and how that renders musical information such as instrument timbre and the realism of voices . There are a number of potential reasons why a audio system might have more third than second harmonic - in that case a pre-amp might the the perfect place to address that problem and add some correcting 2nd harmonic . As I said above, it might only be the difference of something at the -60 to -70dB level from the main signal ; but the human ear is very sensitive to these things.
The 4P1L is a very interesting valve in this regard , as you can run it in several different ways . For instance if you wanted some extra 2nd harmonic, you could run it as a pentode with a lowish anode load of 2 or 3k .
Old 11th January 2013, 03:31 PM   #379
regal is offline regal  United States
Thanks for cleaning up my skimpy schematic, but 150V B+ is much too low.
Good operating point for this tube is 200-230V 30mA.
So that means you have a B+ of about 275V for the first tube with the CCS or gyrator, then use an extra RC to give the 200V B+ for the second tube.
I have 4 of the 4p1l's and am determined to build this when I finish this DAC B.S. But I am on the fence between Grados, Senns, and Orthos. So something to keep in mind when you buy your transformer is you might not want to be tied down to only a 300 ohm tap.
Also to add confusion if you read the ecp article linked above about parafeed, you will really get frustrated cause finding a permalloy core custom para-feed transformer is impossible.
A high quality permalloy 5k:300+32 parafeed OPT would be a real nice to have for preamp builders because it would give a nice headphone output. Kill two birds with one stone.
Old 11th January 2013, 04:25 PM   #380
This shoudn't be a big problem, have you considered Dave Slagle at Intact Audio ? - this is the sort of thing he's always ready to discuss :
:: Index
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
