One more 4P1L SE
One more 4P1L SE
Old 9th January 2013, 10:57 AM   #341
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Arrived the tubes
Ale how much did you paid for teflon loctal tube sockets from Jakeband?
Old 9th January 2013, 12:52 PM   #342
andyjevans is offline andyjevans  United Kingdom
Be careful of teflon loctal tube sockets. Teflon is very slippy. What happens is that the inner part comes up when you pull the tube out of its socket. At least it does on mine. I've stopped using them.
And of course, with loctal sockets you need to open up the bottom of this inner part where it locks the tube pin or you'll have hell taking it in and out. Use a thin nose pliers for instance.
Old 9th January 2013, 01:07 PM   #343
Thanks for advice Andy, BTW Ale teflon sockets looks very nice and don't seems to suffer the same problem like yours.
loctal socket | Bartola Valves
Old 9th January 2013, 01:47 PM   #344
Damn - those are nice! Quite different from the usual teflon types. That central part, however, might still start to slip if it isn't held in pretty securely by the construction. I can't quite see if they lock or not. These days, locking is a just a pain and quite unnecessary.
Old 9th January 2013, 05:39 PM   #345
mogliaa is offline mogliaa  United Kingdom
mogliaa's Avatar
One more 4P1L SE
They are very well made. Get in touch directly with Jakeband if you are interested, but they are not cheap as are handmade and by order.
A great socket is the NOS Russian ceramic one: it locks nicely and perfectly!Not sure how easy is to find these:
Ale
"A mistake is always forgivable, rarely excusable and always unacceptable. " (Robert Fripp)
http://www.bartola.co.uk/valves/
Old 9th January 2013, 05:59 PM   #346
Are these?
Tube Socket, Loctal :: 8-pin Octal Sockets :: Sockets - Tubes :: Interconnects :: Electronic Parts :: Banzai Music GmbH
Old 9th January 2013, 06:24 PM   #347
mogliaa's Avatar
One more 4P1L SE
Yes, they look like the ones I have.
Old 9th January 2013, 06:26 PM   #348
Thanls Ale I ordered a couple.
Old 9th January 2013, 06:29 PM   #349
10pcs ceramic B8G 8pin LOCTAL BOTTOM PCB MOUNT tube socket for 5B254 | eBay
The ones I use are Chinese as above. The ones I used to have a lot of and dislike intensely are these. They corroded, pins fell off, middle pulled up with the tube (2nd one down):
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
These look interesting:
1 Tube Socket loctal for C3g C3m C3o Siemens Telefunken Post Rohre | eBay
These are the Russian type - they come shielded and unshielded.
Loctal sockets shielded used Lot of 8 | eBay
I don't know if a 4P1L goes into a shielded socket, and I'm even more unsure of how you'd get it out except by pushing it from the bottom!!!
Old 9th January 2013, 07:22 PM   #350
I ordered also a couple from Moscow, Russia, here:
''GSTube.com''. Tubes, sockets etc. Search result for <u>pl3-5-14</u>
One more 4P1L SEHide this!Advertise here!
Russian-English Translation of 4P1L datasheet 316a Tubes / Valves 21 2nd January 2017 05:37 PM
pentode in triode mode SE vs a DHT SE like 2a3/300b jarthel Tubes / Valves 67 8th July 2014 01:51 AM
Rare audiophile stereo tube SE amplifier DIY kit (6C2C + 4P1L). mik190 Swap Meet 7 1st November 2010 07:59 AM
Can the Golden Tube Audio SE-40 SE drive 16 ohm woofers? nelsondog Everything Else 1 11th November 2007 05:00 PM
Parallel SE vs. Single SE Output Question valveitude Tubes / Valves 19 4th May 2005 05:36 PM
Copyright ©1999-2017 diyAudio
